Author Topic: Monitor picture doubling upon EDID emulation activation  (Read 2814 times)
liukang7
  • Last login:May 05, 2024, 02:15:29 pm
« on: July 15, 2023, 08:37:55 pm »
Hello everyone. I am attempting to install groovymame and crtemudriver to play MK1-UMK3 in a dedicated cabinet on a Wells Gardener K7000 monitor. I have an HP Workstation Z230 running a fresh install of Windows 10, the newest release of mame and groovymame, and crtemudriver 2.0. I am using an AMD Radeon HD 7700 graphics card and a DVI-I adapter to VGA. The VGA goes into a GBS-8100 that then splices into the RGB ground and sync wires of the monitor. I get a picture on the monitor through this in 640x480, but when I activate EDID emulation and start mame the picture doubles on top of itself and flickers. Sometimes the issue happens only when I am in groovymame and it disappears upon closing it, but sometimes it starts as soon as emulation is enabled. I am unsure of what is causing this other than if the GBS-8100 is interfering with it, but I am otherwise unsure of how to connect the VGA wire to the monitor. If there is any more info I can provide let me know and I can. Thanks!
buttersoft
  • Last login:Today at 07:11:31 pm
  • Is running at 15kHz
Re: Monitor picture doubling upon EDID emulation activation
« Reply #1 on: July 17, 2023, 12:11:18 am »
Can you remove the GBS-8100 from the signal chain and test if that helps?
liukang7
« Reply #2 on: July 17, 2023, 01:31:04 am »
How do I go about connecting the VGA cable to the wires of the monitor?
liukang7
« Reply #4 on: July 17, 2023, 10:18:20 pm »
Thank you! I will update when it arrives.  :D
liukang7
« Reply #5 on: July 19, 2023, 09:40:40 pm »
Update: It works! Thank you so much for the suggestion I would not have figured that out on my own.  When I wired it up I had issues with vertical scrolling but once I enabled composite sync and adjusted the values in the monitor file it fixed it. Looks awesome now   :D
buttersoft
« Reply #6 on: July 20, 2023, 06:34:42 pm »
Nice job! Happy to help, though TBH i was just eliminating one, technically unneeded, link in the chain to narrow down the problem. Glad to hear it worked, lol :)
Next step would be to report the issue to the GBS-control thread on Shmups. Might be valuable info to them.
« Last Edit: July 20, 2023, 09:14:48 pm by buttersoft »
