Author Topic: Any printable patterns for DIY screen bezels?  (Read 1933 times)
90sCadeReadyUp
  • Last login:August 17, 2023, 11:29:15 pm
« on: June 25, 2023, 09:17:51 pm »
I'm looking to make some with either poster board or foam board, as I have a ton of both. Are there any good patterns I can print that are already tried and true?
yamatetsu
  • Last login:Yesterday at 11:25:49 am
  • Just because.
Re: Any printable patterns for DIY screen bezels?
« Reply #1 on: June 26, 2023, 02:49:55 am »
http://forum.arcadecontrols.com/index.php/topic,17175.0.html $2 bezel.
Not a pattern as such, but tried and true. You can go from there.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 12:32:14 am
« Reply #2 on: June 26, 2023, 09:09:21 am »
Made a $2 bezel a few months ago, roughly following that guide... except it cost even less, around 50c. Only needed a single sheet of card / poster board.
Once it was right, I used staples, in behind, to keep the tabs together. This looked even better than I imagined it would. The tabs and    staples are completely invisible when bezel is installed, and made the finished bezel feel a lot more resilient too. Used one of those tiny office staplers, a few per tab join.
Used a little PVA glue (for wood & paper), no staples, for the main structural tab connections (around the edges/corners where the sides join). These must sit tight and flush under glass or metal, so staples wouldn't work.
http://forum.arcadecontrols.com/index.php/topic,166352.msg1765519.html#msg1765519
90sCadeReadyUp
« Reply #3 on: June 26, 2023, 11:45:01 am »
Awesome, thanks!
