Author Topic: GroovyArcade com jpac fora de sincronismo na tela principal.  (Read 2390 times)
Diogo
  • Last login:December 18, 2023, 07:29:04 pm
  • Learn a little every day ....
Hello... I have a problem: I installed GroovyArcade, I'm using a monitor (electrocian), and to connect to the pc I use a jpac... but when I leave a game... the game selection screen is all messed up and the synchronism light on the jpac goes out.
What can it be? I ask friends for patience because I'm using Google translator. Thank you all.
« Last Edit: June 18, 2023, 03:55:43 pm by Diogo »
Calamity
  • Moderator
  • Last login:May 15, 2026, 03:21:10 am
  • Quote me with care
Re: GroovyArcade com jpac fora de sincronismo na tela principal.
« Reply #1 on: July 01, 2023, 06:11:16 am »
Hi Diogo,
If you unplug the usb cable from the jpac and plug it again after a moment, does it sync properly then? If it does, that's a known issue with the jpac.
Steps to create a log:
Diogo
« Reply #2 on: July 03, 2023, 10:00:02 am »
It returns to normal when I move the monitor's horizontal trimpot...
I can't adjust the screen of any game because there's always a black band on the left side...even going into the game's own settings (F2) and trying to adjust the grid, there's always a dark band on the left side.
(AMD 5750 1gb video card, a tube I took from a tv, an arcade monitor (from the electromatic brand) and a jpac (with jumpers at 15 and 31khz))
Thank you for answering and trying to help me, I know it's not an easy task because I'm kind of "uncle" for these things and I don't even know how to create a log.
https://www.youtube.com/shorts/sG-51NqnMfg
https://www.youtube.com/shorts/zS5hLISUOBg
Substring
  • Last login:Today at 03:24:10 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #3 on: July 03, 2023, 04:11:21 pm »
for logs: run gaseutp, go to the troubleshooting menu, and give the link. You need an internet connection
