Author Topic: Perfect 360 wiring  (Read 1550 times)
Zatoichi
  • Last login:March 04, 2004, 03:25:44 pm
  • : P
Perfect 360 wiring
« on: March 04, 2004, 12:47:38 am »
Hello, I have made several arcade controllers. And they have all gone well, with very few problems. And I recently got a P360. And I can't figure something out. I am wiring the arcade controls to a playstation controller. And I look at the p360 and it has 4 prongs, one for each direction. But Im used to having to wire the main, and the ground (two wires for each direction). So how do I connect just one wire to the playstation pad?
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Re:Perfect 360 wiring
« Reply #1 on: March 04, 2004, 07:12:31 am »
just use the ground on the P360 as your common ground for all 4 directions.  ;D
Enjoying the fruits of technological obsolescence one game at a time...
paigeoliver
  • Awesome face!
« Reply #2 on: March 04, 2004, 07:58:35 am »
Your p 360 also needs +5 volts, and I have no idea if your playstation can provide that voltage (or if it can provide that voltage grounded to the ground on the playstation pad).
DYNAGOD
« Reply #3 on: March 04, 2004, 10:56:38 am »
if its a playstation 2 dual shock analog stick there should be juice.
between the eccentric motors for the vibration and the LED for the analog indicator there is definetly juice.
but what flavor its coming in i dont know,you should check the hardware bible and see if theres a PS2 dual shock controller pinout.
TalkingOctopus
    • My Arcade
« Reply #4 on: March 04, 2004, 11:22:10 am »
These guys wire a P360 to a ps controller.  They have plenty of instructions and pictures.
http://mywebpages.comcast.net/jdpyle1/controls_playstation.htm
Good Luck!
Zatoichi
  • : P
« Reply #5 on: March 04, 2004, 05:18:14 pm »
thanks for the link. I may try it that way. I guess I just thought that maybe the 5 volt connections should be seperate from the directions.
