Author Topic: nt-2701 vs nt-2701n  (Read 1281 times)
merkin
  • Last login:June 11, 2023, 04:27:10 pm
nt-2701 vs nt-2701n
« on: June 10, 2023, 02:27:45 am »
Does anyone know the difference between neo-tec's nt-2701 and nt-2701n?
The service manual for the nt-270x family does not mention anything..
Am I correct in assuming the nt-2701 is positive sync and nt-2701n is negative sync?
Long story short I have an nt-2701 but having a sync issue with gt4 complete.
If I am reading the schematic in the service manual correctly, it appears the nt-2701 is configured for positive sync, but can easily be converted to negative sync by swapping a couple discrete components.
I know I could just test it by swapping the parts, but I would also like my suspicions to be confirmed by someone more experienced.
grantspain
  • Last login:Yesterday at 02:56:13 am
Re: nt-2701 vs nt-2701n
« Reply #1 on: June 10, 2023, 05:57:39 pm »
i have only worked on a few 2701 and none have been + sync, + sync was pretty much only used on very early game boards from 70's to early 80's
is the golden tee fore io board set to 25khz or 15khz?
merkin
« Reply #2 on: June 11, 2023, 04:19:05 pm »
@grantspain
The dip switch is set for 25khz.
So here is my confusion..
LA7851 application circuit from Sanyo:
Neotec NT-2701 schematic:
It seems that according to Sanyo in order for the Neotec to be in negative sync, R401 & R402 should be flopped and C403 needs to be swapped out with a 470p cap.
Again Neotec maybe could have designed other parts of the circuit to handle the pulse differently, but I can't read schematics that well enough to confirm.
grantspain
« Reply #3 on: June 12, 2023, 04:16:35 am »
i would find it hard to believe that neotec ran a production line of positive sync chassis after 1981
the horizontal hold pot gives you no difference? R414
