Author Topic: New setup off centered on arcade crt  (Read 2562 times)
ggonxhi@gmail.com
  • Last login:May 01, 2023, 08:29:31 pm
« on: May 01, 2023, 08:15:24 pm »
Good afternoon.
I recently setup a new pc with groovemame and crt emudriver 2.0.
The video card I’m running is a Amd Radeon hd 7500
I have tried arcade osd but to no help.
Am I missing something here.
bobbyb13
  • Last login:July 21, 2026, 01:26:33 pm
Re: New setup off centered on arcade crt
« Reply #1 on: May 01, 2023, 09:38:19 pm »
Need to know what chassis you're running there.
Most have a width adjustment coil and also a centering adjustment via a jumper on the board.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 06:22:28 am
« Reply #2 on: May 01, 2023, 10:24:07 pm »
^^ This. You can pretty much just use the default settings. then twiddle some pots until it looks good. It is probably all you really need for an arcade monitor.
There are ways to tweak CRTEMU settings to get the mode geometry looking right, from adjusting monitor presets prior to generating/installing modes, to fiddling modes directly using arcade_OSD, even slider controls available in-game. but these are more useful for people using CRT TVs. Unlike arcade monitors, TVs usually have very limited, or no, provision for changing the screen geometry.
If you really want to down the rabbit hole, read the pinned thread on monitor presets. Once you get these right everything else falls into place.
insx
  • Last login:August 16, 2025, 06:17:23 pm
  • I dabble in Retropie and virtual pinball
« Reply #3 on: July 18, 2023, 11:50:13 am »
I have a TV with some good geometry controls via a special menu but the screen positioning varies a lot from game to game.
