Author Topic: Rowe AMI R88 doens't work  (Read 3358 times)
Nick2001
  • Last login:March 11, 2023, 11:25:12 am
« on: March 11, 2023, 11:25:27 am »
Dear Forum Users,
Recently I have come into possession of this beautiful jukebox.
Only at first I had the following problem:
1. When the jukebox is turned on, it grabs the single that the magazine is on. (so does not spin)
2. This single is played immediately, but without sound.
3. If you enter any number on the selection. sound comes out of the jukebox.
4. When the single is finished it puts it back in the magazine
5. The magazine starts spinning and does not stop spinning. Also, the jukebox no longer responds to anything.
The MAG Motor LED is on.
The Opt Sw Index is flashing.
And the Opt Sw Home is flashing at location 99.
Meanwhile, the problem has changed to the following:
When I turn on the jukebox. the magazine spins around 1x.
Then it stands still and the jukebox does nothing.
Where do i start looking for this problem
southofi-10
  • Last login:May 24, 2023, 10:55:32 pm
Re: Rowe AMI R88 doens't work
« Reply #1 on: May 24, 2023, 10:55:32 pm »
I would check the solder connections on all boards,including the pricing board below the computer.Check all connections
cqlink
  • Last login:November 09, 2023, 01:03:20 am
« Reply #2 on: June 02, 2023, 01:59:34 am »
Have you called Bruce or Jeremy at A&B Jukebox?  I’d give them a shout.
