Author Topic: Happ button to remotely start/shutdown pc?  (Read 2411 times)
bioart
  • Last login:November 28, 2006, 11:38:14 pm
    • The ArtCade
« on: March 02, 2004, 11:08:36 am »
Hi All,
What kind of button do I need to wire to the MB header on the PC? is it just a simple button going to either the always open or always closed (whichever it is) or is it a different kind?
I'd like to mount the button somewhere in the back or (front below the control panel) so that I can turn the everything on from it (using a smart strip to power everything on when the PC turns on...)
Art
PS: Check out my UA2 cabinet in progress...
http://bioart.net/bioartcade
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Happ button to remotely start/shutdown pc?
« Reply #1 on: March 02, 2004, 11:48:07 am »
Most pcs use a normally open momentary switch for turning on.  This would include probably just about all buttons that Happ sells (yes it does include the "normal" arcade buttons).  I used #275-618 from Radio Shack instead because I like the look of the button.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #2 on: March 02, 2004, 05:58:04 pm »
i have mine wired to a regular pushbutton right now from happs...but i was also looking for a cooler looking method for turning on the cab.  could i get one of those silver/metal flip switches?  you know, the silver rod switch that goes either up or down (on/off) almost like a toggle switch.  maybe thats the name of it.  would that have the NO and GND things that i need similar to the pushbutton???
2600
« Reply #3 on: March 02, 2004, 07:34:21 pm »
Hulkster, you want cool look at this.
http://www.frozencpu.com/cgi-bin/frozencpu/ele-70.html
hulkster
« Reply #4 on: March 02, 2004, 09:06:23 pm »
well that is really cool, but id rather have like a switch to flip.
solfood
  • Last login:November 22, 2006, 04:25:10 pm
  • all your rights are belong to Ashcroft
« Reply #5 on: March 03, 2004, 12:04:59 am »
www.mcmaster.com
has some cool LED tipped toggle switches.  Most PC power switches that I've seen are momentary contact.  I'm sure someone makes a momentary contact toggle though.  I remember using one in a model rocket launcher I built when I was a kid.
JustMichael
« Reply #6 on: March 03, 2004, 12:26:57 am »
hulkster081,  some pc's will NOT work with a toggle switch.  My regular pc would be a prime example.  It will not startup until after I release the power button.
Stingray
« Reply #7 on: March 03, 2004, 01:54:56 pm »
There are momentary toggles out there. I know I've seen them, just don't remember where.
-S
xcalibur
  • Last login:August 22, 2012, 11:15:35 pm
  • You sold my dead bird to a blind kid?
    • Dallas Starcade
« Reply #8 on: March 03, 2004, 01:59:59 pm »
I'm planning on using this http://www.cyberguys.com/templates/searchdetail.asp?T1=161+2210
It should connect to the headers just linke the current switch now...
« Last Edit: March 03, 2004, 02:01:02 pm by xcalibur »
Thanks,
hulkster
« Reply #9 on: March 03, 2004, 06:08:19 pm »
oooooooo....thats super cool!  so will it have the same connectors?  i need a NO and GND connection cuz i have two wires (with quick disc.) on them.
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #10 on: March 03, 2004, 07:14:59 pm »
If it's a momentary, it will work.  But beware, some momentaries are normally closed, and the circuit opens when you flip the switch.  Not paying attention bit me in the butt a while back.
Be sure it's a N.O. switch.
They do make momentary toggles.  Other electronic sources are:
www.mouser.com
www.digikey.com
I believe Mouser has a $25 minimum order though...
hulkster
« Reply #11 on: March 03, 2004, 07:25:04 pm »
well i did a google search for "momentary toggle switch" since i didnt know the official name before...and found a few sites.  this is what im looking for http://www.holley.com/HiOctn/ProdLine/Products/NOS/NOSCA/15603NOS.html  but how can i tell if it will work or not?
Stormy151
« Reply #12 on: March 04, 2004, 12:42:17 am »
That one will probably work, but it looks like a 3 position, On-Off-On.  The center pole is the common.
Stingray
« Reply #13 on: March 04, 2004, 10:20:28 am »
Yeah, that three position switch should do the trick.
-S
bioart
    • The ArtCade
« Reply #14 on: March 06, 2004, 09:21:06 pm »
I think I came up with a solution that works for me... my coin door had four buttons inside for rst/maintenance etc.  I rewired two of them and used the wiring harness to wire them to the motherboard headers.  I also wired the lights to the 12V power from the PC...
I may wire the other two buttons to the ipac sometime later... :)
