Author Topic: Converting to Sanwa - Help  (Read 1335 times)
RetroReign
  • Last login:December 26, 2022, 11:25:40 am
  • Stuck in the 80s
« on: December 18, 2022, 10:02:33 am »
I have an Arcade Legends 3 and Galaga Reunion cabinet that I want to swap the US style joysticks to Sanwa joysticks with the servo controlled 4 to 8-way gate.  My goal is to have two machines that can do both 4 and 8 way to cover both vertical and horizontal games.  The Arcade Legends is a top-mount, wooden panel with carriage bolts while the reunion cabinet is the standard metal control panel.  What is the best method to convert these?  How do I adjust the depths between the metal and wood to achieve the proper ball height?  Is that done via mounting depth, or can you buy different shafts for the joystick?
SSLArcade
  • Last login:December 21, 2022, 03:11:51 am
Re: Converting to Sanwa - Help
« Reply #1 on: December 20, 2022, 05:03:40 am »
Hello, Joystick can add extender to make it fit.
