Author Topic: Romsets for original arcade machines  (Read 2980 times)
Greenman
  • Last login:January 03, 2025, 06:02:48 pm
  • Made in Australia
« on: October 24, 2022, 05:44:26 pm »
Hi all.
I want to get into burning my own eproms and was wondering if they are the same files as are used in mame?  Sorry for the neub question.  If not, where would I access the roms for the PCB boards I currently own?
Thanks.
My previous projects:
  • Last login:Today at 03:07:20 am
Re: Romsets for original arcade machines
« Reply #1 on: October 24, 2022, 07:07:17 pm »
Yes, assuming that MAME has them confirmed as good dumps.
Here's an example of how to tell which ROM file goes with which IC on the PCB.
If you look in the "xybots.zip" file, there is a file named "136054-1101.5c".
- "136054-1101" is the part number.
- "5c" is the grid location on the PCB.
If you look at page 48 of the manual here, you see a drawing of the PCB.
- There are a series of numbers on the left/right and a series of letters on the top/bottom that form a layout grid.  These numbers and letters are also printed on the PCB.
- If you look where row 5 meets column c, you see a large IC labeled "136054-XX01" in the PCB drawing.
- Looking at the parts list on page 49, Designator 5C is Part No. "136054-1101" and the Description is "Integrated Circuit, EPROM, 2764-300".
You now know what ROM file to burn to a 2764-300 EPROM to replace the IC located at 5c on the Xybots PCB.   :cheers:
Greenman
  • Made in Australia
« Reply #2 on: October 24, 2022, 11:15:54 pm »
Thank you Scott.  If I could buy you a beer, I would.   :applaud:
Paul.
« Reply #3 on: October 25, 2022, 04:04:44 am »
Glad to assist.   :cheers:
