Author Topic: Pi4 to jamma help Using HDMI to VGA adapter and a JPAC from Ultimarc  (Read 9470 times)
mamemaniac
  • Last login:May 05, 2026, 07:54:15 pm
Greetings,
I have a pi4 arcade image I want to use for an arcade monitor running a 15khz CGA resolution. So I tried using a HDMI to VGA adapter into a JPAC from Ultimarc with no luck. I can seem to get the correct settings in the CFG file on the pi image. Has anyone figured out the correct settings that can help me please???
