Author Topic: CRT Emudriver and Raden HD8490 not working  (Read 1827 times)
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
« on: August 13, 2022, 10:38:01 am »
Hi guys,
I'm trying to install CRT Emudriver and GM on my Pc Dell 3020 sff|Core i5-4570|8gb|ssd 240GB|Radeon HD8490 1GB| Win10.
The only drivers that correctly recognizes the graphic card is: CRT Emudriver & CRT Tools 2.0 beta 15 (Crimson 16.2.1 non-GCN* cards) for Windows 7/8/10 64-bits, but but when I enable EDID emulation my crt monitor is out of frequency.
If I uninstall the CRT Emudriver, Win10 automatically installs AMD Catalyst 15.201, and if I enable EDID emulation I can see the desktop on my crt monitor, but I can't install super resolutions (rejected by the driver).
Can anyone help me? Thanks in advance!  :)
buttersoft
  • Last login:Today at 06:47:35 am
  • Is running at 15kHz
Re: CRT Emudriver and Raden HD8490 not working
« Reply #1 on: August 14, 2022, 01:13:38 am »
Errr, is the CRT a PC monitor, by any chance? Most PC CRT monitors only take ~31kHz and above (640x480p) and CRT_emudriver is primarily designed for 15kHz output (640x480i or 320x240p). It can work with higher frequencies, but you have it set for Arcade_15 which is definitely 15kHz only.
« Last Edit: August 14, 2022, 01:19:25 am by buttersoft »
SuperMagoAlex
« Reply #2 on: August 16, 2022, 06:41:15 pm »
Hi, yes it's a Sony Trinitron 14" TV.
I solved the problem after 4 or 5 install/unistall Crimson drivers... and finally the image was displayed also on the TV  :notworthy:
