Author Topic: Using trackball in place of spinner?  (Read 1292 times)
ATWindsor
  • Last login:August 04, 2022, 02:05:59 pm
« on: July 30, 2022, 02:37:13 pm »
I am looking to build my first cabinet, I don't envision using many games that uses a spinner, but i wondered if it could work to use a single trackball axis as a "spinner" in games like araknoid? Or is this not really feasible?
  • Last login:Today at 01:05:46 am
Re: Using trackball in place of spinner?
« Reply #1 on: July 31, 2022, 01:41:25 am »
Trackballs are usually lower resolution than spinners, but many spinner games will work well enough with a trackball.
- You may need to adjust the sensitivity in the MAME "Analog Controls" menu.
Some games like Arkanoid used geared spinners that provide a much higher resolution (more transitions) for a given amount of rotation.
- Those games might not work well enough even if you increase the sensitivity.
Try various spinner games, play around with the sensitivity, and see if you like them.   ;D
ATWindsor
« Reply #2 on: July 31, 2022, 04:35:57 am »
Thanks, I don't have a trackball, so i can't really try, I am in the planning phase. But it seems like a trackball can work somewhat reasonable.
