Author Topic: Difference in CRT_EMUs??  (Read 3250 times)
B2K24
  • Last login:June 10, 2025, 10:17:56 am
« on: July 26, 2022, 02:39:52 pm »
Hi,
Can someone knowledgeable please explain the differences? More specifically the differences between 4XXX and 5XXX series?
Is there that much difference before I place an order?
Thanks for any help and assistance.
Download CRT Emudriver & CRT Tools 2.0 beta 15 (Catalyst 12.6) for Windows 7/8/10 64-bits
Desktop: AMD Radeon™ HD 2000, HD 3000, HD 4000 series
Download CRT Emudriver & CRT Tools 2.0 beta 15 (Crimson 16.2.1 non-GCN* cards) for Windows 7/8/10 64-bits
Desktop: AMD Radeon™ HD 5000, HD 6000 Series, HD 7000-7600, HD 8000-8400 Series
psakhis
  • Last login:September 24, 2024, 11:54:25 am
Re: Difference in CRT_EMUs??
« Reply #1 on: July 26, 2022, 03:40:32 pm »
Hi, you have better support from 5xxx series.
bobbyb13
  • Last login:Today at 12:20:45 am
« Reply #2 on: July 26, 2022, 04:12:07 pm »
I have had a much easier time using a more recent/powerful card and the Crimson flavor drivers.
Specifically a video card with both dvi (for the pc monitor) and vga (for the crt) outputs to be able to have two screens working at the same time throughout the install process.
The key is that whatever card you have that you are using the appropriate driver, be it the Catalyst ones or Crimson.
buttersoft
  • Last login:Yesterday at 06:49:09 pm
  • Is running at 15kHz
« Reply #3 on: July 27, 2022, 05:11:45 am »
The 5000 series and newer cards allow EDID emulation. You want EDID emulation.
The drivers are newer and work better.
Calamity
  • Moderator
  • Last login:Yesterday at 11:25:39 am
  • Quote me with care
« Reply #4 on: July 27, 2022, 06:22:59 am »
Keep in mind that video cards are manufactured for a certain Windows (DirectX) version:
- HD 4000 series -> Direct3D 10 -> Windows Vista
- HD 5000 series -> Direct3D 11 -> Windows 7 +
Basically anyone using Windows 7 or newer must use HD 5000 or newer. Using a HD 4000 on Windows 7 is possible but its support is let's say hacky and problematic.
In order to make their pre-HD 5000 series compatible with WDDM 1.0 (Vista), ATI stuck a compatiblity layer on top of their old Windows XP drivers. That's what you still have if you want to use an HD 4000 card on Windows 10.
HD 5000 were the first cards with native WDDM 1.0 support, rewritten from scratch.
In short (since Vista is pointless): use HD 4000 for Windows XP and 5000+ for anything newer.
« Last Edit: July 27, 2022, 06:25:13 am by Calamity »
Steps to create a log:
B2K24
« Reply #5 on: July 27, 2022, 11:51:44 am »
Thank you so much!!!
I'm happy I ordered a HD 7450 now to go with a spare rig I had lying around.
gamer83
  • Last login:September 13, 2022, 05:50:54 pm
« Reply #6 on: August 01, 2022, 09:40:47 pm »
 ...Using a HD 4000 on Windows 7 is possible but its support is let's say hacky and problematic.
would one of those problems be rendering dual screen games like punchout or arm wrestling? or vertical games? Im using an HD4xxx card in win7 x64 and havent figured out how to display punchout properly in an over under format that fits the screen. I also had a problem with some vertical shooter games running at 50% and in an interlaced super resolution, I fixed the shooters by creating an custom ini and changing the resolution for the problem games which took forever, but still cant figure out punchout. Could I have avoided all this trouble by just using a HD5xxx or newer card?
