Author Topic: Cabinet Sound/Speakers/Amp Help  (Read 1552 times)
yrrkoon
  • Last login:February 02, 2023, 11:46:51 am
  • I like to build things
    • arcadecabinetproject.blogspot.com/
« on: July 13, 2022, 10:33:01 am »
Hey All,
I decided to save myself some time and headache and to start an upright cabinet using one of those kits on Etsy. I'm hoping to get some feedback on what would make for some good sound options. The speaker panel calls for 4" speakers. Ultimately, I'm putting a windows PC in the cabinet which has a sound blaster card.
I'm not entirely sure what the best solution is for sound. A part of me wants to just somehow put a set of 2.1 computer speakers in there somehow but it's not like you can really mount them behind the grill. Another part of me wants to put proper 4" speakers in there, an amp, and a sub and wire it all up. But I don't know what to buy to piece together a halfway decent sound system.
Any suggestions on some (common?) options?
Thx!
RandyT
  • Last login:June 18, 2026, 02:39:45 pm
    • GroovyGameGear.com
Re: Cabinet Sound/Speakers/Amp Help
« Reply #1 on: July 13, 2022, 01:48:48 pm »
Long before there were CLASS-D mini amplifiers on the cheap, I found a 2.1 speaker setup intended for the N64 on clearance at a ToysRUs and just positioned the satellites behind the speaker cutouts and put the main amp/sub inside of the cabinet.  It was hacky, but sounded great and couldn't be beat for the money.
That stated, there are a lot of good options now in the way of cheap mini amps and plenty of speaker options to roll your own system for not too much money.  If the cabinet will double as a jukebox, go wild.  Otherwise, you don't need anything expensive or fancy for old arcade games.  Very few of them were even in stereo, let alone in high fidelity.  But I do recommend some sort of larger, low-range driver inside the cab to give the smaller speakers a bit more oomph and fill the sounds out better.
There's no shame in using a PC 2.1 audio setup, so long as it sounds good, can be made to physically fit your space, is hidden from view and checks all your preference boxes.  Hot melt and/or plastic plumbing strap and a few screws can help in mounting the satellites.
