Author Topic: H Sync issue  (Read 1945 times)
mikew72
  • Last login:July 21, 2023, 04:55:55 pm
H Sync issue
« on: July 08, 2022, 11:05:34 am »
I have a JAMMA cabinet with a 25" intervideo standard resolution monitor in it.
When first powered up, the horizontal sync always needs adjusting to get a stable picture.  Once adjusted, the image is fine until turned off and left for a while.  Next time it's turned back on it will need adjusting again.
I've tried it with my NEOGEO, a PC/JPAC and a Pacman clone JAMMA board.  It's the same on all so I'm fairly confident it's an issue with the monitor, though I can't rule out the JAMMA harness.
The monitor dates from 1992 so I was thinking of giving it a recap, but I was also wondering if the potentiometer on the adjustment board may need replacing too?
Mike
grantspain
Re: H Sync issue
« Reply #1 on: July 08, 2022, 11:47:54 am »
wise to do all you mentioned, check for bad solder joints as well
  • Last login:Yesterday at 08:50:13 pm
Re: H Sync issue
« Reply #2 on: July 08, 2022, 12:27:21 pm »
Mike
Mark the position of the pot. Squirt it with deoxit. Turn it back and forth a bunch to clean it out. Fire the monitor back up and see if that helps.
