Author Topic: 3500 in 1 jamma board No VGA Signal Please help!  (Read 3461 times)
valdy
  • Last login:July 19, 2022, 10:23:54 am
« on: June 24, 2022, 11:04:07 am »
Hi Guys,
I just bought a 4 player creative arcades 2nd hand and it has a 3500 in 1 jamma games family inside.
After much trouble shooting I'm incline to believe that the 64 SSD may have died.
I was wondering, does anyone have a hard drive image I could download? I already have an ssd to test and hopefully it boots.
Currently I have no vga signal and no sound even tho fan spins and green light with mobo.
Everything is connected correctly inside and tested a different power supply with no luck.
If anyone could please help me I would certainly appreciate it.
Folder with pictures if you are interested.
https://imgur.com/a/Hma2xzp
UPDATE
This are all the things I've done and unfortunately I have the same result. Jamma board gets a green light, CPU Fan spins, no video signal no audio.
+change power supply
+changed VGA cable
+Changed monitor
+SSD WORKS FINE. plugged it to another pc and can see the content
+CPU WORKS FINE. Replaced it with another working one and it made no difference.
+MOVED RAM TO DIF SLOT.
+Put a new stick of RAM.
+tried booting w/o any RAM.
+tried booting w/o ssd.
« Last Edit: July 12, 2022, 01:49:58 pm by valdy »
