Author Topic: ServoStik Issues  (Read 1378 times)
AnthonyJS02
  • Last login:August 07, 2022, 03:08:54 pm
ServoStik Issues
« on: June 21, 2022, 10:53:25 pm »
Took about 8 months off working on my pedestal/arcade/pinball setup. Just now getting back into it and finally messing with my servostik. Installing the motor and run the test application and not getting anything once i hit the 8way button. The motor on the switch is not moving at all. I even uninstalled from under the control panel and it is not moving with anything attached to the arm. I get the windows notification when i plug the USB in. I hit 4 way in the servostik.exe and it highlights yellow. I hit the 8way button and nothing. Could i have a bad motor? And i figured i should mention is running it off a laptop the issue? Figure i wouldnt mention incase power issue.
Tony
