Author Topic: dual-booting Groovyarcade and Windows 10; any caveats?  (Read 2081 times)
kendjet
  • Last login:April 02, 2022, 06:49:30 pm
« on: February 28, 2022, 05:18:18 am »
Hi all,
I'm planning on buying a 2nd SSD drive to install Groovyarcade, as I read that it needs its own drive (since it destroys the existing partitions).
Is anyone running a dual-boot with Windows 10? So right now I already have Windows 10 running, but I'm not sure if Groovyarcade will adjust the bootloader properly.
I should be using the BIOS in Legacy mode right? Are there any other things I should be aware of?
Calamity
  • Moderator
  • Last login:Today at 05:16:21 pm
  • Quote me with care
Re: dual-booting Groovyarcade and Windows 10; any caveats?
« Reply #1 on: February 28, 2022, 05:24:47 am »
I have Win 8.1 (sic) + GA, on 2 different SSD drives, no problems.
Just be careful during installation to point to the correct drive, you know what I mean.
Use UEFI installation if your BIOS supports it, it works great. You won't see a boot menu after installation (grub, etc.) if that's what you expect. You'll have to manually press F8 or whatever key your BIOS uses to bring its built in boot drive menu, and pick the one you want. If nothing is pressed, it'll boot from the default drive (by BIOS selection).
Steps to create a log:
kendjet
« Reply #2 on: March 03, 2022, 03:05:40 am »
Thank you Calamity!
Once GA is installed to the new SSD I bought, can I just leave the VGA cable connected to my Radeon HD4650 and the HDMI cable to the other graphics card permanently? Won't that cause any issues when I start Windows or GA?
Thanks ;-)
