Author Topic: Crosshatch squares should be square (equal width and height)?  (Read 2584 times)
jimj
  • Last login:August 27, 2024, 06:39:31 pm
« on: January 29, 2022, 06:13:15 pm »
This probably falls under the "duh" category, but I just want to be certain before I go through the effort to calibrate my monitor's geometry that I'm doing it correctly.
When using a crosshatch test pattern I assume the squares should be true squares (equal width and height, for example 1cm wide by 1cm tall) and not rectangles with a 4:3 aspect ratio (for example 4cm wide by 3cm tall)?
I plan on using in-game test mode cross hatch test screens to calibrate my monitor (unless someone has a better or easier way they want to share).
buttersoft
  • Last login:Yesterday at 07:32:27 pm
  • Is running at 15kHz
Re: Crosshatch squares should be square (equal width and height)?
« Reply #1 on: January 30, 2022, 04:59:22 pm »
When using a crosshatch test pattern I assume the squares should be true squares[?]
Yes. No CRT is perfect though, and the older they get, the more you may have to learn to live with. They generally make up for it in other way :)
jimj
« Reply #2 on: January 30, 2022, 05:04:09 pm »
Thanks for confirming.  Yes, I look at any imperfections as adding to the to authentic 1980s arcade realism where things usually weren't perfect.  :)
