Author Topic: CRT goes out of sync when exiting game  (Read 4704 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: January 21, 2022, 04:29:41 pm »
I'm trying to figure out why CRT goes out of sync when exiting a 640x 480 (H) 60 Hz game like Street Fighter EX2.
I'm using an AMD Radeon HD 5450 and so far every other game I've tested (which isn't a whole lot at this point) exits back into BigBox just fine.  The game displays fine too, it's just when you exit it to go back into BigBox.  Any help is appreciated.
buttersoft
  • Last login:Today at 06:48:03 am
  • Is running at 15kHz
Re: CRT goes out of sync when exiting game
« Reply #1 on: January 21, 2022, 10:12:48 pm »
Have you stopped and disabled the service called AMD External Events Utility?
tkuper05
« Reply #2 on: January 21, 2022, 10:49:01 pm »
AMD External Events Utility was running.  I stopped it and changed it to disabled.  Unfortunately that didn't help.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 05:43:55 am
« Reply #3 on: January 22, 2022, 08:32:59 am »
Create a log per Calamity's instructions (in sig of every post)
tkuper05
« Reply #4 on: January 22, 2022, 10:27:22 am »
I've attached the log.
tkuper05
« Reply #5 on: January 22, 2022, 02:34:05 pm »
I have a stupid question.  My monitor is a RGB modded consumer TV.  Should I be using the NTSC Monitor Preset or the Arcade 15.7 KHz one>
Zebidee
  • Trade Count: (+9)
« Reply #6 on: January 22, 2022, 05:52:30 pm »
Start with the generic_15khz presets.
Hopefully Calamity will have some time soon to look over your log and the exit issue
buttersoft
« Reply #7 on: January 23, 2022, 08:07:26 pm »
I'm going to open my mouth and state i reckon this is a front-end problem, and nothing to do with GM. If you open GM by itself, run a problem game, exit, and the PC goes back to desktop at the expected resolution every time, the problem must be with BigBox.
I have very similar issues with a lot of games in Attractmode, for which i use DC2, batfiles and AHK scripts, depending. Doesn't happen in MAME, but a few more windows updates should do it :/
Zebidee
  • Trade Count: (+9)
« Reply #8 on: January 23, 2022, 08:59:14 pm »
Agreed. It was nagging me before that you reported the issue happening when returning to BigBox. If you can't replicate the issue when running Groovymame directly, outside of BB, then it must be a BB issue   :dunno
tkuper05
« Reply #9 on: January 24, 2022, 08:58:05 pm »
I tested the issue with GM only and it's the same result so I don't think it's a BB issue.
