Author Topic: groovymame crashes windows 7 on new setup  (Read 3267 times)
trick72
  • Last login:April 25, 2026, 11:13:58 am
« on: January 11, 2022, 09:35:56 am »
Hi,
in short:
- Windows 7 64bit AMD 6700 series video card with a 31khz CRT arcade monitor
- connection is a hdmi to vga adapter to the analog VGA port of my 31khz CRT arcade monitor (only input it has is an analog vga connector)
- My AMD graphics card has an analog VGA too, but when I connect it directly to the monitor with a analog vga cable I have only a black screen. It seems to not go into sync, not even during boot up or in the post-bios screen. The analog vga works with a normal PC lcd monitor, but not with the arcade monitor. When I use the hmdi port and a vga adapter it does work.
- latest CRT emudriver, modelines generated and installed. When using arcade_osd I can see the installed video modes, and can select them and when I do, I see the raster screen (red/green) and the selected video mode fine.
- when launching groovymame (with admin rights), the system hangs. I see a black screen with the mouse pointer wheel. I can do ctrl-alt-del to end-task groovymame but it keeps hanging, and can't do anything. Windows 7 seems to hang as well, cannot shutdown/restart. Only option is to switch off the PC. When i press CTRL-ALT-DEL to go to task manager while MAME is running,  I do see that the actual resolution has changed to the requested low resolution needed for my test game Arkanoid as everything looks "bigger". So it seems the resolution was switched fine to the requested resolution but mame itself hangs.
- I also tested the official mame build, and that works fine for arkanoid on this same setup. It runs fine and I can play the game.
- I created a log file and attached it to this post. I checked it briefly but I don't see any error messages or weird things in it.
Please help. Thanks
trick72
Re: groovymame crashes windows 7 on new setup
« Reply #1 on: January 14, 2022, 03:36:59 am »
topic can be closed.
I solved it. Seems it was the Realtek Audio over HDMI that was enabled that caused it. Is disabled this (since I use HDMI for VGA) and now it works fine.
