Author Topic: Problems with PPJoy  (Read 3964 times)
dommer
  • Last login:February 20, 2016, 06:54:10 am
Problems with PPJoy
« on: February 27, 2004, 02:40:03 am »
I cant seem to get ppjoy installed.  When I run setup, right after selecting to install the unsigned driver, I get an error message saying that the driver could not be copied, "You will need to manually install the device drivers."
Then whenever I attempt to run it, it says it cant communicate with the device, the device doesnt show up in the device manager, and I get the following in the event manager:
Source: PPJoy
The description for Event ID ( 2063 ) in Source ( PPJoyBus ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: , 0.78.0.000.
Any ideas?
walls83
  • beer is good
Re:Problems with PPJoy
« Reply #1 on: February 27, 2004, 03:08:02 am »
Im having problems with PPjoy myself but I got mine installed but I cant get a joystick to emulat on the keyboard... arrgggg
walls83
  • beer is good
« Reply #2 on: February 27, 2004, 03:26:32 am »
Source: PPJoy
Any ideas?
did you go into the control panel and load the drivers from there.  If you read the website it has a walk through on how to do it.
dommer
« Reply #3 on: February 27, 2004, 09:24:56 am »
Yeah, when I do that, it says that it cannot find the specified file.  When I open up the inf file, the only file I see referenced that isn't available is layout.inf.  Hmm, well I'll keep at it, I'll post if I find anything out.
