Author Topic: CRT Emudriver Error - No AMD Graphics Driver is installed  (Read 3378 times)
philexile
  • Last login:October 30, 2022, 03:45:01 pm
  • I want to build my a GroovyMame PC!
« on: September 29, 2021, 10:59:53 pm »
Hello,
I'm having an issue with CRT Emudriver. I had to update my Windows 10 machine, and as a result, reinstall CRT Emudriver. The driver version is 15.301.1901.0
The install is run as an administration and is successful, but after each restart a dialog box appears stating: No AMD graphics driver is installed, or the AMD driver is not functioning properly . . etc. Also, Windows 10 is in Test Mode.
I uninstalled/reinstalled CRT Emudriver a few times, but this is always the result. The install is also always successful - and CRT Emudrive does work.
One odd thing is that I do not have access to the Start menu after the install. I needed to hold cntl-alt-delete to access the restart function that way.
In the video card properties, under events it says: Device install requested, requires further installation.
Any ideas?
Thank you
philexile
Re: CRT Emudriver Error - No AMD Graphics Driver is installed
« Reply #1 on: September 29, 2021, 11:08:24 pm »
Please disregard — I had been installing the incorrect driver for my video card — r9 380.
Thank you
