Author Topic: Rowe R-90 45 jukebox  (Read 5151 times)
Boombaby
  • Last login:September 17, 2021, 07:02:17 am
« on: September 16, 2021, 03:49:13 pm »
I have a rower-90. 45 jukebox that slows way down then picks back up while playing a 45. Usually happens after a few minutes of play. Do have a err36 but I think that is a cancel switch prob. Any ideas on what I could be looking g for. I’m no professional but can usually fix most things myself. Any advice would be great. Thanks
Ken Layton
  • Guru
  • Technician
Re: Rowe R-90 45 jukebox
« Reply #1 on: September 16, 2021, 10:37:15 pm »
Error 36 is the cancel signal is always low.
As to the slowing down problem, inspect the Mechanism Control Board for bad solder joints at the connector header pins.
Boombaby
« Reply #2 on: September 17, 2021, 07:02:18 am »
Thanks so much. I will try and check that out this weekend.
