Author Topic: Mayflash DolphinBar always on IR leds mod  (Read 4255 times)
DSR!
  • Last login:September 15, 2021, 06:40:13 pm
« on: September 04, 2021, 08:10:22 pm »
For use new versions of dolphinbar (firmware V09) as regular bar you need to force WL8U signal pin to 3.3volts.
How do you do that?
Solder a wire from the vcc ping test to the 4 pin of the WL8U and enjoy it!
Some pictures of the process
You can see the complete image gallery here
https://imgur.com/a/vSxuX2p
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
Re: Mayflash DolphinBar always on IR leds mod
« Reply #1 on: September 05, 2021, 02:02:12 am »
What is the benefit of having it on all the time?
DSR!
« Reply #2 on: September 05, 2021, 02:21:41 pm »
I use it as follows:
For windows games: Dolphinbar in mode 2
For emulators/mame: Touchmote and remapping according to the game
So by modeling the bar I can use it as the case as a common bar
Vocalitus
« Reply #3 on: September 05, 2021, 07:32:52 pm »
Sorry but I have a dolphin bar on mode 2 and it works with all my pc based light gun games so I guess the one I have doesn't modifying?  How can I tell?
DSR!
« Reply #4 on: September 05, 2021, 11:07:56 pm »
that's why I made the separation between windows and emulated games
emulated games only worked well for me with touchmote, or at least that happened to me in my tests
also so it could connect without problems up to 4 controls
Vocalitus
« Reply #5 on: September 06, 2021, 03:04:08 pm »
I understand now.  I can only get one controller to work without messing around with a nunchuk add on.  I will try this out.  Thanks for the help.  :cheers:
