Author Topic: How to get 3 x spinners mapped in mame64?  (Read 3360 times)
wezfunlab
  • Last login:January 09, 2023, 12:13:51 pm
« on: August 28, 2021, 10:13:56 pm »
Hi there, I can easily get 2 x spinners mapped to the x and y axis of a mouse but I’m having trouble getting the 3rd spinner mapped? Does anyone have any ideas?
wezfunlab
Re: How to get 3 x spinners mapped in mame64?
« Reply #1 on: August 28, 2021, 10:36:40 pm »
FYI - I have 3 x GRS spinners. I have 1 x 12 in 1 interface.
  • Last login:Today at 04:46:21 am
« Reply #2 on: August 28, 2021, 11:48:36 pm »
Are you using a PC or an Arcade1Up 12-in-1 machine?
Looks like that interface is designed to connect a trackball and a spinner at the same time to an A1Up 12-in-1 machine, not a PC.
- Pretty sure the spinner shares an axis with the trackball.  i.e. you can use the spinner on the X-axis or the trackball on the X-axis and Y-axis, but you can't use both controls at the same time.
wezfunlab
« Reply #3 on: August 29, 2021, 12:04:36 am »
PC,  I have two spinners working. I can map one spinner to the mouse Y axis and the other spinner to the X axis. This works fine so you can have a two player setup. However it’s the 3rd spinner I need help with, I’m not sure if I get another usb interface if I can map the other spinner to another mouse?
« Reply #4 on: August 29, 2021, 12:46:18 am »
Yes you can.  You'll need to modify "mame.ini" to enable multimouse then map each spinner's axis.
Mame.ini isn't created automatically when you install MAME.
Run your MAME executable with the "-cc" (create config) software switch to generate mame.ini. i.e. "mame.exe -cc"
- You only need to do this once.
- You should find mame.ini in the "mame" folder or "ini" sub-folder.
Open mame.ini using Notepad.
- Set mouse and multimouse to enabled (1) instead of disabled. (0)
- Save file and exit.
Code: [Select]
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
You can now map each spinner's axis separately.
- Easy way is to do this is to remap the defaults under the MAME "Input (general)" P1/P2 menus.
If you've already remapped buttons in a game, MAME created a custom .cfg file for that game and you'll need to either delete the .cfg file (.\mame\cfg\" folder) or reset each axis in the game to default or remap each axis in the game.
To reset the axis to the new default:
- Press TAB to enter the MAME menu system.
- Go to the "Input (this game)" menu.
- Highlight the axis.
- Press ENTER. (map the setting)
- Press ESC. (set it to none)
- Press ESC. (reset it to default)
Any axis using an optical (mouse/spinner/trackball) control should have the "Dec" and "Inc" set to none.
Those are reserved for key presses being substituted for analogue input.
- Highlight the "Inc" or "Dec" setting.
wezfunlab
« Reply #5 on: August 29, 2021, 02:32:04 am »
Thanks so you can map it to each mouse? I couldn’t get mame to see the second mouse as an option after that mame.ini change? You just see mouse X and mouse Y even though I have two mouses plugged in to my pc?
« Reply #6 on: August 29, 2021, 10:41:02 am »
1. Do all of the mouse/spinner axes move the cursor in Windows?
- If Windows doesn't see the spinner inputs MAME won't see them either.
2. Did you restart MAME after enabling mouse + multimouse (i.e. change "multimouse   0" to "multimouse   1") and saving mame.ini?
3. Did you then remap the "Dial analog" inputs?
- Go to the "Input (general)" P1/P2/P3 menus to set MAME defaults or the "Input (this game)" menu for game-specific settings.
- Highlight the axis you want to map.
- Move the spinner to map that mouse axis to that input.
-- It should remap the input from "Mouse X" to something like "Mouse1 X" or "Mouse3 Y".
