Author Topic: Vertical bartop - "SHMUPIN" *Complete* - upgraded 2024 :-)  (Read 56748 times)
firedance
  • Last login:September 05, 2026, 02:31:04 pm
Re: Vertical bartop - "SHMUPIN"
« Reply #40 on: June 12, 2022, 09:46:48 am »
Thanks, itching to put it all together but don't wanna rush it  :)
firedance
« Reply #41 on: June 15, 2022, 01:18:28 pm »
Had a good few hours today working on putting it together and wiring, will save the completed pictures for another day  ;)
Been a lot of fun but also frustrating working in such a small space inside the bartop, trying to fit all the wiring in and make sure it doesn't foul the fans or get pinched when it's together.
Still need to work on the config for the controls as sometimes it skips letters on it's own or it doesn't always switch to pinball or back again, am sure i'll get it sorted  ;D
YES it is fully together and playable as i lost an hour just picking random games and testing them out, tempest is surprisingly easy with a joystick  >:D
TTFN  :)
firedance
« Reply #42 on: June 17, 2022, 10:37:51 am »
Sorted (mostly) the software side of things as it now boots straight to coinops (used the guide on here) have left the pointer visible, only shows for a few seconds, just in case i need to alter anything.
Just need a PVC/plastic L trim (out of stock at the moment) for the top and it's done, the back is a very snug fit, as once it's unscrewed you have to gentle tug at the fan grill to prise it open  :o, have used a wireless mini keyboard so shouldn't need to open it up anyways.
The side button led doesn't seem that bright in person, warning stickers i printed myself along with the side sticker, knocked it together in about 10 mins then printed on matt vinyl i had laying around, kinda reminds me of a power up in many games  ;)
It's still a bit quirky in the coinops menu, need some more research when i can be bothered  >:D
Only EXTRA costs are the wood grain vinyl and L trim (once back in stock) so call it £8.80 for a finished machine  ;)
Well that's it i guess for this build...................until the next  :)
  • Last login:August 25, 2026, 02:00:37 pm
« Reply #43 on: June 17, 2022, 10:39:37 am »
I like the woodgrain.
zeorangr
  • Last login:Today at 07:50:30 pm
    • forum.arcadecontrols.com/index.php/topic,165836.0.html
Re: Vertical bartop - "SHMUPIN" *Complete*
« Reply #44 on: June 17, 2022, 04:26:58 pm »
This is a really neat mini cabinet.  Nice work!
-z-
firedance
« Reply #45 on: June 17, 2022, 04:57:38 pm »
Thanks, just don't look too closely as there are many imperfections  ;)
« Reply #46 on: June 18, 2022, 08:14:36 am »
So you have the marquee dynamically changing with the game?  That's a nice touch.
firedance
« Reply #47 on: June 18, 2022, 10:54:00 am »
The marquees are all to do with the layouts in MAME via coinops
Yes each game as its own marquee, the files are stored in artwork.
firedance
« Reply #48 on: August 13, 2023, 07:37:01 am »
Hey Guys n Gals,
Managed to get a slight upgrade for the thin client, picked one up for only £35 Delivered, just like the one in this link  -
https://www.parkytowers.me.uk/thin/wyse/5060/
Should be able to wire the power switch like i did before BUT can't see an easy 12v source for the fans, there are tiny solder points for a connector that i used on the original thin client, not sure if i can solder that small tho and would they be live anyway without the connector ??? or i could use a sata extender cable and tap into the 12v/ground wires or would that cause too much trouble for the SSD, thoughts ?
if i can get it work then the plan is swap them over then stick maybe retroarch on the older one and give it away to a nephew for Christmas :)
markc74
  • Last login:August 31, 2026, 04:13:23 am
  • Flipping out
« Reply #49 on: August 16, 2023, 06:32:31 pm »
That's pretty cool. I was thinking of doing something similar in the next few months so enjoyed reading this.  :cheers:
firedance
« Reply #50 on: August 16, 2023, 11:42:18 pm »
Glad you liked it :)
If you have any questions about this build, I'll be more than happy to help.
  • Last login:Today at 03:06:24 pm
« Reply #51 on: August 17, 2023, 03:19:17 pm »
This came out great.  Got a video or something walking through how it all works?
Is there a CoinOps download without all the games just with the vertical layout? Just like a normal front end - I can only seem to find large downloads.  I like the idea of using a monitor in portrait mode with dynamic marquees but only need 80 or so games and not everything under the sun. Seems like it would be easier to add my own games and marquees instead of downloading a huge file and try to strip it back...
firedance
« Reply #52 on: August 18, 2023, 03:45:01 am »
Will see what I can do but that busy with work and with holidays coming up as well.
firedance
« Reply #53 on: August 22, 2023, 08:57:16 am »
Hi javeryh,
Have messaged you twice but not sure the messaging service is working as they aren't in my sent box  :o
  • Last login:Today at 05:02:41 pm
« Reply #54 on: August 22, 2023, 12:49:17 pm »
That's because you don't currently have that option enabled.
Go to the "Personal Messaging" menu in your profile . . .
http://forum.arcadecontrols.com/index.php?action=profile;area=pmprefs;u=34132
. . . and check the "Save a copy of each personal message in my sent items by default" box.   :cheers:
firedance
« Reply #55 on: August 22, 2023, 01:02:22 pm »
Thanks for the heads up, first time i've had to do that on any forum :)
« Reply #56 on: August 24, 2023, 11:06:03 am »
I haven't received any messages...
firedance
« Reply #57 on: August 24, 2023, 02:41:28 pm »
Hopefully you should get a message now 🙂
firedance
« Reply #58 on: August 27, 2023, 07:05:39 am »
Hey Guys n Gals,
Couldn't get a 12v source, even from the SATA port when i used an adapter like in the first post, almost all 2.5" HDD's and all SSD's seem to just use 5v from what google says, so i'll keep "shumpin" as it is and a nephew can get a better retro gaming mini pc :)
firedance
« Reply #59 on: August 01, 2024, 07:38:48 am »
Well it has been almost a year so here is a update  ;D, a few months I tried to power the fans via USB, some fans don't even turn on with 5v, they seem to work ok so installed the newer slightly faster thin client inside, used a DP to VGA adapter from eBay, still haven't given the older one to my nephew but his birthday is coming up soon or maybe Christmas  :lol
firedance
« Reply #60 on: August 01, 2024, 07:50:41 am »
jeremymtc
  • Last login:August 27, 2026, 05:40:29 am
« Reply #61 on: August 01, 2024, 08:34:27 pm »
Nice on the upgrade! Do you notice any performance improvement?
I had a similar issue with triggering my 12V fan relay from a 5V source which was seeing voltage droop down to a little over 2V, and ended up having to find a more stable switched 5V source for the trigger - the 5V rail exposed for the harddrive ended up being pretty bulletproof.
firedance
« Reply #62 on: August 02, 2024, 12:16:31 am »
Thanks for the fan tip, will see how they go :)
A few of the more demanding shooters are more playable now as it's almost double the performance   :)
firedance
« Reply #63 on: August 02, 2024, 12:19:45 am »
Well it has been almost a year so here is a update  ;D, a few months ago I tried to power the fans via USB, some fans don't even turn on with 5v, they seem to work ok so installed the newer slightly faster thin client inside, used a DP to VGA adapter from eBay, still haven't given the older one to my nephew but his birthday is coming up soon or maybe Christmas  :lol
