Author Topic: Magstick Plus Joysticks Installation  (Read 1990 times)
Batapotamus
  • Last login:August 31, 2021, 11:56:11 pm
« on: August 10, 2021, 12:05:10 am »
It's been a good five or six years since I started building my arcade cabinet due to family commitments and life in general and I'm ready to finish it off finally now but in that time I've forgotten how I planned to mount th Joysticks. I can't remember if I was going to bottom or top mount the Joysticks. My control panel is 16mm MDF with 3mm plexiglass with the artwork sandwiched inbetween.
Not sure if I should route the top to place the Joysticks baseplate or have the baseplate routed and fitted from underneath the control panel?
bobbyb13
  • Last login:September 18, 2026, 03:56:14 am
Re: Magstick Plus Joysticks Installation
« Reply #1 on: August 10, 2021, 03:05:41 am »
If you aren't using a metal mounting plate to sit on top (under your artwork) then you want to rout out the bottom side.
If you leave any less mdf than 7-8mm or so you may have problems with panel flex.
