Author Topic: Having video troubles with Nintendo Vs. board & JAMMA  (Read 2494 times)
DalyTek
  • Last login:December 07, 2022, 07:59:42 pm
« on: July 10, 2021, 12:17:35 pm »
Hi all.  I'm going to do my best to describe my problem, but I am relatively new to this, so please bear with me.
I built a cabinet from scratch, with the sole intent of making a dedicated Super Mario Bros. machine.  At first, I used a 19-in-one JAMMA board, paired with a CGA-to-VGA converter, and had all the other games disabled so it booted directly into SMB.  This worked, but the game was emulated in this board and I didn't like the performance.  I wanted the real deal.  So I bought a tested good Vs. Unisystem Super Mario Bros. board, and I bought a Vs. to JAMMA converter board from pcbjunkie.net.  These are still running into the above mentioned CGA-to-VGA converter into a 19" LCD screen.
I am having troubles with the video on this setup.  It's just a garbled mess.  The system board, the Vs. to JAMMA board, and the video converter board all have their own respective RGB trim pots on them.  I spent all day yesterday trying various combinations of tweaking these.  I was able to get the display to show, but not clearly, and there is a noticeable green overtone to everything and the video seems to intermittently cut out.  if it matters, the settings for the pots that so far show the display the clearest are: CGA-VGA converter: RP1:all the way left, RP2 & RP3: 1bout 1/3 up; JAMMA converter: all 3 all the way to the right; Nintendo Vs. board: all about middle (but these 3 don't have a pronounced effect at all.)
I am attaching a pic of the screen as best I can get it, showing the graphical glitches.
Does anyone have any advice on what I can do to get this up and running correctly?  Greatly appreciate any and all advice!
« Last Edit: July 10, 2021, 01:24:45 pm by DalyTek »
Ken Layton
  • Guru
  • Technician
Re: Having video troubles with Nintendo Vs. board & JAMMA
« Reply #1 on: July 10, 2021, 08:18:21 pm »
Original Nintendo boards output an inverted video signal. Your JAMMA board outputs standard arcade video signals.
You need to buy a video inverter board such as this one from Mike's Arcade:
https://www.mikesarcade.com/cgi-bin/store.pl?sku=NININVAMP
DalyTek
« Reply #2 on: July 10, 2021, 09:56:58 pm »
I believe that my JAMMA adapter has this same circuitry built into it.
This is what I have:
http://pcbjunkie.net/index.php/jamma-adapters/nintendo-vs-to-jamma-adapter/
