Author Topic: Rowe - R84 External phonograph hookup  (Read 3248 times)
jayt
  • Last login:March 31, 2021, 12:02:03 am
  • I want to know all about my AMI/Rowe R-84!
« on: March 29, 2021, 12:22:49 pm »
I recently got a Rowe R-84 and was looking at the best scenario to add an external phonograph (or eventually any music player) to it. I have read so much about it that many things are running together now. One mentioned I might have to remove the record motor belt for it to play properly. I do not want this option because I want to be able to use the jukebox too without have to keep modifying things.
I have the Rowe R-84
I have the 125 Watt Stereo Amplifier 6-07438-02
Can someone tell me the best option?
jayt
Re: Rowe - R84 External phonograph hookup
« Reply #1 on: March 29, 2021, 11:34:02 pm »
I was searching eBay and found this option:
AMI ROWE JUKEBOX AMPLIFIER PREAMP ACCESSORY BOARD # - 60792702
Is this the route I should go? Would it work for what I am looking for. I asked the guy on eBay and he said he had no clue, he sold for a third party.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 31, 2021, 12:39:32 am »
Here is the instructions for that kit:
https://arcarc.xmission.com/PDF_Jukebox/Rowe_AMI/Rowe_Amplifier_Accessory_Board_Kit_26694703_(Rev_3-93).pdf
I think it is for models R-89 up thru the CD100F. Check with Bruce Wentworth to confirm. I think your R-84 would use a different amplifier accessory kit and the kit number should be listed in your field service manual under accessories.
