Author Topic: What's the best way to mount defender joystick in metal control panel?  (Read 2826 times)
Ap1
  • Last login:July 14, 2021, 08:15:58 pm
What's the best way to mount defender joystick in metal control panel? I'm concerned about the height of the joystick and how would I compensate for that?
I have not had any luck searching for this answer.
« Last Edit: March 25, 2021, 06:28:59 pm by Ap1 »
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
Are we talking about an original 2 way or a zippy with a two way restrictor plate?
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
Pack the panel out to a thickness of 21mm to match the Williams Defender panel.
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
Ap1
Quote from: Vocalitus
No a repro original from Arcadeshop I guess although I was looking at Zippy's and the GGG  Leaf-Pro™ True Leaf-Switch Joystick. Not many other solutions I can find. Thank you Vocalitus
Quote from: jimmer
Ahh so a piece of 3/4 plywood is 18.0086mm here in the states. So I need to find something 3mm thick to stack on top for a proper height. Jimmer is there a template to cut out such a mounting?
Edit: I'm more asking about the hole size in the metal panel itself. What's the best way to cut this out? Is it with a Dremel and cut wheel?
« Last Edit: March 25, 2021, 07:56:59 pm by Ap1 »
jimmer
The same joystick was used in Stargate 19mm panel, by putting the washer in a different position, see attached.
18mm ply plus your 2mm? metal panel would be OK with the Defender setup. A bit high is better than a bit low.
Something like 12mm x28mm for the panel hole.
Ap1
Thank you very much for a great post!
