Author Topic: Problem configuring GroovyMAME for 480p  (Read 2341 times)
Nodoyuna
  • Last login:November 29, 2025, 11:48:41 am
« on: March 20, 2021, 10:26:38 am »
Hi
I have a CRT Emudriver / GroovyMAME setup running perfectly fine on my PVM
Now, I'm trying to make a setup for 480p. The monitor is a modern Full HD 1080p but if I configure the emulators for 480p, they work perfect, displaying in a 480p monitor I have
But, I'm having problems making GroovyMAME works in the same way. I prefer to use GroovyMAME over regular MAME because of the switchres feature.
When I run GroovyMAME , it gives an error, stating "Could not find a videomode that meets your specs"
So, which are the settings I need to write on mame.ini in order to make it work at 480p? Do I need to make some additional steps?
Thanks in advance
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
Re: Problem configuring GroovyMAME for 480p
« Reply #1 on: March 20, 2021, 10:38:24 am »
If I remember well, in mame.ini set:
switchres                 0
modeline_generation       0
Nodoyuna
« Reply #2 on: March 20, 2021, 01:31:23 pm »
So, the only option is disabling switchres?
Also, what about resolutions above 480p? For example, some computers does have more resolution than 640x480
Thanks in advance
« Last Edit: March 20, 2021, 02:55:34 pm by Nodoyuna »
