Author Topic: Second U360 only showing buttons  (Read 1344 times)
Nappa313
  • Last login:April 28, 2021, 02:20:47 pm
« on: March 07, 2021, 06:38:50 am »
Hello,
I知 running into an issue where in windows game controllers my second U360 is showing 32 buttons instead of 15 and also not showing the x/y axis for some reason. The first player u360 is showing up normal but my second one is acting this way. Anyone know what I知 doing wrong? Thank you for your time.
« Last Edit: March 07, 2021, 10:36:47 am by Nappa313 »
  • Last login:Today at 04:28:37 am
Re: Second U360 only showing buttons
« Reply #1 on: March 07, 2021, 07:16:39 am »
I知 running into an issue where I知 windows game controllers my second U360 is only showing 32 buttons instead of 15 and also not showing the x/y axis for some reason. The first player u360 is showing up normal but my second one is acting this way. Anyone know what I知 doing wrong?
If you've changed the ID on the bad stick as mentioned in the installation directions and the bad stick is behaving the same when the good stick isn't plugged into a USB port, I don't think you're doing anything wrong.
Assigning an ID:
When the joysticks are supplied, all are set to an ID of ONE. You must change as required so IDs in use are unique.
What you're describing sounds like the HID definition (# of buttons and axes) in the firmware is messed up.   :dizzy:
E-mail Andy at Ultimarc and he should be able to help you resolve this issue.
Nappa313
« Reply #2 on: March 07, 2021, 08:00:38 am »
Hey Scott,
Thank you for the reply. So yes, I did assign both joysticks and they were both registering at one point. In the ultimarc software the x/y axis shows up and works but in windows game controllers the second joystick only shows as 32 buttons and after being wired none of them are registering. It痴 really weird considering player 1 works normal after installing the wiring harness and this happens. I did email Andy and I知 waiting on the reply. Thanks again!
