Author Topic: Nintendo Ball Tops  (Read 2469 times)
Scotty
  • Last login:May 01, 2025, 09:16:56 am
Nintendo Ball Tops
« on: February 24, 2021, 01:07:59 pm »
Did Nintendo use the standard 6mm screw thread for their 25 and 28mm ball tops?   In other words, can I screw a 25 or 28mm on the top of a Sanwa style stick? If not, is there an adapter?
  • Last login:May 05, 2026, 10:44:49 pm
Re: Nintendo Ball Tops
« Reply #1 on: February 24, 2021, 05:48:14 pm »
Not sure..... I have one but it's buried in my parts bin somewhere.   Imho Nintendo sticks kind of suck.... just use another brand and this is coming from an accused nintendo fanboy. ;)
« Reply #2 on: February 24, 2021, 06:46:42 pm »
I would venture to guess likely, I can say that the old NES advantage was 6mm and I was able to put a JLF balltop on mine. Knowing how Nintendo likes to fall back on their parts, I wouldn't expect them to change sizes.
However, I haven't been able to remove the ball from my cab joysticks and am not going to try to really crank on them to see if I can crack them loose, as I think they are pretty cemented in there.
Scotty
« Reply #3 on: February 26, 2021, 09:41:17 pm »
I just ordered a 25mm and a 28mm from Mikes Arcade.     Hope it works....  If anyone can confirm before it ships, it would be greatly appreciated.
Scotty
« Reply #4 on: March 01, 2021, 11:57:26 am »
Just got a call from Mike at Mike's arcade.  Nintendo used an 8MM thread.  Bummer.  Anyone know of a 6 to 8mm adapter?
« Reply #5 on: March 02, 2021, 01:32:20 pm »
That's too bad.
Well, only speaking in theory, as I haven't done this with anything small, but could you sand off the threading and cut a 6mm thread into it using a tap and die kit?
3:20 mark on this video.
ChanceKJ
« Reply #6 on: March 02, 2021, 05:16:18 pm »
« Last Edit: March 19, 2021, 01:44:51 am by ChanceKJ »
