Author Topic: Ms. Pac Man/Galaga reunion stick - Ball/shaft swap  (Read 1137 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« on: February 23, 2021, 11:07:41 am »
Hi all,
I have a Ms. Pac Man/Galaga reunion stick on my panel whose balltop could use a swap out. I've been unable to remove the ball from the metal shaft to do so. If necessary I'll swap the metal shaft as I already have a replacement balltop (fits Seimitsu/Sanwa) but am a bit concerned that the replacement shaft won't fit.
Would something like this do the trick? I'm having trouble getting specs on the original vs Seimitsu shafts.
www.arcadeworlduk.com/products/hollow-shaft-for-seimitsu-ls-32x-38x-series-of-joysticks-standard-extended.html
TIA
Dexter
