Author Topic: Megatouch evo force block zero error  (Read 7392 times)
Silvercloud1959
  • Last login:February 28, 2021, 09:59:23 pm
« on: February 16, 2021, 06:26:46 pm »
Im going to post a screenshot of the issue im having if someone can point me in the right direction
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: Megatouch evo force block zero error
« Reply #1 on: February 16, 2021, 10:09:37 pm »
Hard drive is either corrupted, or is going bad. Most likely the hard drive is about to die.
Silvercloud1959
« Reply #2 on: February 17, 2021, 05:32:30 pm »
Any idea where i can get a hard drive set up to run?
mahkeymike
« Reply #3 on: February 18, 2021, 06:26:00 am »
For starters, what year version do you have?
Silvercloud1959
« Reply #4 on: February 18, 2021, 07:14:25 pm »
Force 2009
freshfitz
  • Last login:January 29, 2025, 05:17:10 pm
« Reply #5 on: February 26, 2021, 10:20:25 pm »
It's kinda a b.... to load, you'll need the 2009 iso you can find them on the internet and any ide 2.5 hard drive will work. You'll need an IDE DVD drive and you will have to burn the iso on the dvd's or find 2009 restore disks. I had trouble burning the disks I had to decrease the burn rate to 4x. I would just upgrade to a later year and get a later year Dallas key if I were you
Spank
  • Last login:August 18, 2025, 09:34:35 pm
  • I like to help out.
« Reply #6 on: February 27, 2021, 03:16:16 pm »
Force uses 3.5 inch desktop IDE drives.
mahkeymike
« Reply #7 on: February 27, 2021, 08:43:47 pm »
Early versions do. Newer versions used a 3.5 to 2.5 ide adapter.
1st
  • Last login:November 03, 2021, 11:01:33 pm
« Reply #8 on: March 02, 2021, 10:33:21 pm »
Last drive I got was aRuby replacement from "davemaut" or similar. I thought it was fairly reasonable but that was a while back. I have so many spare drives it seems I have all working stuff for what games I can run and the newest software keys I have available. I think SSD is the way to go if getting a replacement?
