Author Topic: What type of adhesive for peeling Vynil.  (Read 2583 times)
Pulp
  • Last login:January 21, 2021, 07:49:13 pm
« on: January 21, 2021, 07:49:13 pm »
I recently purchased a new multicade, 2 weeks later the vinyl graphics on the side are peeling up. Can anyone suggest a good adhesive I can use to glue it back down with, one that wont bleed through? Thanks!
  • Last login:Yesterday at 07:26:12 pm
Re: What type of adhesive for peeling Vynil.
« Reply #1 on: January 21, 2021, 10:34:39 pm »
I would like to know that myself.  The old Gorf machine has some cheap-ass sideart because that was all that was available at the time and the edges are starting to lift.  I'd like to get them stuck down in a way that won't lift off paint when I eventually replace them.
bobbyb13
  • Last login:July 01, 2026, 04:15:57 pm
« Reply #2 on: January 22, 2021, 02:30:12 am »
My default for adhesive has always been 3M Super 77 for a nearly always permanent fix for this kind of application.
No idea how it will treat underlying paint though Howard, as I am sure it is full of all sorts of fun little aromatic hydrocarbon things.
Solvent compatibility is always an issue with regard to paints- a lesson I have learned in various hard ways many times- so always test first if you can.
nitrogen_widget
« Reply #3 on: January 22, 2021, 03:31:39 pm »
Rubber cement?
it holds most of my kids arts and crafts together temporary like pretty good.
shaolindrunkard
  • Last login:February 12, 2026, 11:54:11 am
« Reply #4 on: January 27, 2021, 10:54:11 pm »
Elmer's makes some big ass glue sticks that are extreme hold, you can get them online or at craft stores, I bet that would work well.
https://www.amazon.com/Elmers-E588-Glue-Stick/dp/B00ISZZ48W
bobbyb13
« Reply #5 on: January 27, 2021, 11:22:43 pm »
Thanks for that one.
Have to try that out!
Osirus23
« Reply #6 on: January 28, 2021, 04:27:30 pm »
« Last Edit: August 23, 2021, 01:31:59 pm by Osirus23 »
