Author Topic: Arcade namco light gun to aimtrak  (Read 5092 times)
Immortalhate666
  • Last login:November 19, 2024, 06:03:05 pm
« on: January 18, 2021, 12:51:07 pm »
Ok im thinking about buying of these blue guns orginal arcade guns they used for time crisis 2...
Im wondering what do i all need to convert it to this and
All i know is a psu the recoil kit and the AimTrak Light Gun OEM Electronics Kit
But what else to be able to play this on my pc using mame..
I need soldering pics to see what i have to do
JayBee
  • Last login:July 17, 2025, 11:29:25 am
  • Creator of the GUN4IR
Re: Arcade namco light gun to aimtrak
« Reply #1 on: January 18, 2021, 01:14:27 pm »
I'd recommend you this instead if you want a better modding solution  ;)
http://forum.arcadecontrols.com/index.php/topic,161189.0.html
Immortalhate666
« Reply #2 on: January 18, 2021, 03:21:32 pm »
ok but how would i use this for this type of gun ?
JayBee
« Reply #3 on: January 18, 2021, 08:43:16 pm »
most of it is explained in the pdf guide in the package, and for the namco gun some members of the discord server already modded it, they might be able to help you  ;D
exodus123456
  • Last login:June 09, 2021, 08:40:11 pm
« Reply #4 on: January 26, 2021, 11:09:03 am »
You don't need too much soldering, maybe the trigger and buttons, but that's it, if you're planning on using recoil, that can be a little more complicated, but Aimtrack site has instructions. Anyway, as other user told you, you're WAY BETTER off trying GUN4IR since it has line of sight accuracy, Aimtrack does not, aimtrack is just another wiimote-like solution that can't do line of sight aiming.
