Author Topic: Ultimarc MagStick Plus and Reyann/EasyGet  (Read 3001 times)
San
  • Last login:December 13, 2020, 08:22:07 pm
« on: December 13, 2020, 08:22:48 pm »
Hi everyone,
   Hoping someone can help me out.  I am looking to integrate a MagStick Plus in to my arcade cabinet, but I can’t seem to find a wiring diagram for a Reyann/EasyGet USB encoder.  I will be using retropie, but I am hooking the USB encoder into a Windows box just to test the buttons and joystick calibration.
Thanks,
meyer980
  • Last login:August 16, 2025, 11:20:05 am
  • Building fun things for fun
    • sergiostuff.com/2020/04/15/felix-son-arcade-game/
    • Sergio Stuff
Re: Ultimarc MagStick Plus and Reyann/EasyGet
« Reply #1 on: December 13, 2020, 09:38:45 pm »
Isn't that just another name for the Zero Delay encoders? If so, here ya go: https://images-na.ssl-images-amazon.com/images/I/71LFCa7R6uL._AC_SL1500_.jpg
They're detected as gamepads/joysticks in windows so it's also very easy to test. Plug into a computer, hook up a button, go to "Devices and Printers", right click the Zero Delay controller and choose Game Controller Settings, Click properties, and you'll see a little screen where you can preview each of the buttons pushed and what windows labels them as. I've attached what it looks like for an Xbox controller.
Good luck!
  • Last login:Today at 02:06:03 am
« Reply #2 on: December 13, 2020, 09:43:11 pm »
How about this one?
- Use the 2Pin Joystick connectors hooked to the NO (Normally Open) and COM (Common) tabs on the Mag-Stick microswitches.
- Remember that the actuator moves opposite of the handle so if you push the handle right, the actuator presses the switch on the left.
