Author Topic: Jama 60-1 Multicade upright cabinet. Upgrade?  (Read 2097 times)
pcresqswmr
  • Last login:January 03, 2021, 04:11:55 pm
« on: October 24, 2020, 01:13:12 pm »
I am about to order a replacement 60-1 board and was wondering if I can get the 412-1 instead without too much rewiring or will I be able to just plug into existing harness? Has anyone done this? Thank you for the help in advance!
  • Last login:June 19, 2026, 12:33:17 am
Re: Jama 60-1 Multicade upright cabinet. Upgrade?
« Reply #1 on: October 24, 2020, 01:55:49 pm »
Well if they are both jamma then jamma is jamma.... you can just swap them out.  Take note of the audio though as it isn't always standardized.
  • Last login:Yesterday at 11:27:36 pm
« Reply #2 on: October 24, 2020, 06:23:48 pm »
Watch for the difference between a standard JAMMA harness and a "CHAMMA" (Chinese JAMMA) harness.
- The CHAMMA harness changes some of the unused pins and grounds (pins 25-27+c-e) into button 4-6 inputs for P1 and P2.
- IIRC when pins 27 and e are connected to ground, a CHAMMA PCB won't boot properly because it thinks those buttons are always pressed.
pcresqswmr
« Reply #3 on: October 25, 2020, 10:19:47 am »
Thank you for fast responses. Replacing board as all cintrols stopped working at once. Continuity checks on all grounds are good. I can' t do anything except watch it boot and cycle through demos.
pcresqswmr
« Reply #4 on: November 12, 2020, 12:58:26 pm »
New board was no change or improvement. I did find only 11vdc out of power supply so addressing that now. Has anyone seen that take out all controls? I am in Melbourne Beach Florida if anyone is close by and experienced with the 60-1 multicade.
