Author Topic: Silly question - can I have a default .lay file?  (Read 4960 times)
P-chan
  • Last login:April 13, 2022, 12:39:40 am
« on: October 12, 2020, 12:47:43 am »
I'm on MAME 0.225 and am comfortable with creating .lay files and bezel art.  Ideally the default.lay file would apply to any game that didn't have an actual layout/bezel .zip.
  • Last login:Today at 03:07:20 am
Re: Silly question - can I have a default .lay file?
« Reply #1 on: October 12, 2020, 11:35:53 am »
Pretty sure that's possible but you'll need two .lay files -- one for horizontal games and one for vertical games.
Seems like the widescreen "Generic Horizontal Artwork" (genhorizontal.lay) and "Generic Vertical Artwork" (genvertical.lay) files on Mr.Do's would be a good starting point for your partially-masked vertically-mounted widescreen build.   ;D
https://mrdo.mameworld.info/mame_artwork_ingame.php
P-chan
« Reply #2 on: October 12, 2020, 09:23:21 pm »
Thanks for the link!  I'm ok on creating the generic horiz and vert artwork, I just don't know how to tell MAME to use these files if there isn't an actual layout for that game.  Or do I have to do that manually?
I'm creating the artwork and lay files for most of my favorites, but if anything else is chosen, I want there to be a "default" lay file that's used.
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
« Reply #3 on: October 12, 2020, 09:44:27 pm »
Open up mame.ini, and look for "fallback artwork" and "override artwork".
P-chan
« Reply #4 on: October 14, 2020, 09:04:13 am »
This sounds like what I needed, thanks I'll check it out!
« Reply #5 on: October 14, 2020, 09:17:59 am »
More info on how to make it work with MAME v0.194 or newer at https://www.mameworld.info/mrdo/mame_artwork_generic.php.
