Author Topic: RGBCommander with Recalbox blink my led  (Read 3217 times)
LeSchtroumpf2
  • Last login:October 26, 2020, 12:22:38 pm
« on: October 08, 2020, 09:37:36 am »
Hey !
I'm using Recalbox on PC and i would like my LED to be bright (with PacLed64) ;D
I installed RGBCommander and my led are shinning when i switch on the PC. I tried to play with the animation and it works.
My issue is that when i launch a game, for ex "2048" on "nes", my leds switch off.
The log file contains the sequence : Switch on the pc -> Choose snes -> Launch 2048 -> Escape
Here is the log file :
Code: [Select]
08/10/20 15:29:49  _____ _____ _____                               _
08/10/20 15:29:49 | __  |   __| __  |___ ___ _____ _____ ___ ___ _| |___ ___
08/10/20 15:29:49 |    -|  |  | __ -|  _| . |     |     | .'|   | . | -_|  _|
08/10/20 15:29:49 |__|__|_____|_____|___|___|_|_|_|_|_|_|__,|_|_|___|___|_| 0.4.0.5
08/10/20 15:29:49 Copyright 2015-2018 Gijsbrecht De Waegeneer
08/10/20 15:29:49 RGBcommander 0.4.0.5 linux
08/10/20 15:29:49 a *nix arcade cabinet led and joystick driver
08/10/20 15:29:49
08/10/20 15:29:49 compilation date Dec 23 2017 19:34:30
08/10/20 15:29:49
08/10/20 15:29:49 [INFO] [Init] installation directory -> /usr/sbin/rgbcommander/
08/10/20 15:29:49 [INFO] [Init] daemon binary -> rgbcmdd
08/10/20 15:29:49 [INFO] [Init] working directory set to -> /recalbox/share/system/rgbcommander/
08/10/20 15:29:49 [INFO] [Init] minimame binary build source -> 0.188 (mame0188) -> processed 38188 structures
08/10/20 15:29:49 [DEBUG] [Hardware] constructed PACLED64_1 hwthrottle -> 625
08/10/20 15:29:49 [INFO] [Init] processed 21 buttons
08/10/20 15:29:49 [INFO] [Init] processed LedBoard PACLED64_1
08/10/20 15:29:49 [DEBUG] [Hardware] constructed SERVOSTIK hwthrottle -> 0
08/10/20 15:29:49 [INFO] [Init] processed Joystick SERVOSTIK
08/10/20 15:29:49 [INFO] [Init] daemon listening port number 2724
08/10/20 15:29:49 [INFO] [Init] blinking mame led mappings : led 0 -> P1_START led 1 -> P2_START led 2 -> P1_BUTTON1
08/10/20 15:29:49 [INFO] [Init] static maps defined -> true
08/10/20 15:29:49 [INFO] [Init] # defined emulators in data structure -> 1
08/10/20 15:29:49 [INFO] [Init] -> megadrive
08/10/20 15:29:49 [INFO] [Init] # defined process to watch -> 2
08/10/20 15:29:49 [INFO] [Init] -> retroarch
08/10/20 15:29:49 [INFO] [Init] # emulators defined as retropie (retroarch cores and/or normal processes) -> 0
08/10/20 15:29:49 [INFO] [Init] # emulators defined as arcade (mame derivates) -> 0
08/10/20 15:29:49 [INFO] [Init] # retropie folder to process mappings -> 0
08/10/20 15:29:49 [INFO] [Init] processed 3 flash animations
08/10/20 15:29:49 [INFO] [Init] processed 1 animations
08/10/20 15:29:49 [INFO] [Init] total Init processing time -> 0.0601263s
08/10/20 15:29:49 [DEBUG] [ControlPanel] constructed ControlPanel
08/10/20 15:29:49 [INFO] [execOutputHook] exec hook -> "/recalbox/share/system/rgbcommander/scripts/OnDaemonStart.sh"
08/10/20 15:29:49 [INFO] [main] successfully created ControlPanel abstraction
08/10/20 15:29:49 [INFO] [rgbcmddMsgQueue] starting rgbcmdd message queue thread
08/10/20 15:29:49 [INFO] [processMonitor] awaiting FrontEnd (emulationstatio) start...
08/10/20 15:29:49 [INFO] [mameNetworkCommunicator] mameNetworkCommunicator started
08/10/20 15:29:49 [INFO] [mamefifo] starting sdlmame monitoring thread
08/10/20 15:29:49 [INFO] [startListening] selectserver: listening on IP 0.0.0.0, socket 15
08/10/20 15:29:49 [DEBUG] [processMonitorWorker] starting processMonitorWorker
08/10/20 15:29:49 [WARNING] [startListening] selectserver: bind failed, error: 98
08/10/20 15:29:49 [INFO] [RGBAstart]random animation chosen -> dissolveinout_32
08/10/20 15:29:49 [INFO] [fadeSpeed] PACLED64_1 fadespeed set to  0 -> SUCCESS
08/10/20 15:29:50 [INFO] [setRGBAspeed] RGBA dissolveinout_32 speed set to 100
08/10/20 15:29:50 [INFO] [RGBAthread] rgba dissolveinout_32 play back start at speed 100
08/10/20 15:30:03 [DEBUG] [rgbcmddMsgQueue] msg from rgbparse -> emu -> nes -> rom -> 2048 (tsone)
08/10/20 15:30:03 [ERROR] [rgbcmddMsgQueue] no process tied to nes -> correct rgbcmdd.xml! Ignoring this command.
08/10/20 15:30:04 [INFO] [RGBAstop] awaiting animation stop...
08/10/20 15:30:04 [INFO] [fadeSpeed] PACLED64_1 fadespeed set to  0 -> SUCCESS
08/10/20 15:30:04 [INFO] [RGBAthread] rgba dissolveinout_32 playback stop -> anim runtime ->  14.4988s
08/10/20 15:30:04 [INFO] [RGBAstop] animation stop -> success ...
08/10/20 15:30:04 [INFO] [processMonitor] retroarch is running
08/10/20 15:30:04 [INFO] [setState] setting state for retroarch default
08/10/20 15:30:04 [WARNING] [setState] inexistent emulator -> retroarch -> abort
08/10/20 15:30:26 [INFO] [processMonitor] retroarch is no longer running
08/10/20 15:30:26 [INFO] [setStick] committing state to joystick hardware -> SERVOSTIK
08/10/20 15:30:26 [WARNING] [connect] failed to detect deviceSERVOSTIK
08/10/20 15:30:26 [INFO] [setWay] setting SERVOSTIK to 8 failure
08/10/20 15:30:26 [INFO] [execOutputHook] exec hook -> "/recalbox/share/system/rgbcommander/scripts/OnEmuStop.sh"  'retroarch'
08/10/20 15:30:26 [INFO] [RGBAstart]random animation chosen -> dissolveinout_32
08/10/20 15:30:26 [INFO] [fadeSpeed] PACLED64_1 fadespeed set to  0 -> SUCCESS
08/10/20 15:30:26 [INFO] [setRGBAspeed] RGBA dissolveinout_32 speed set to 100
08/10/20 15:30:26 [INFO] [RGBAthread] rgba dissolveinout_32 play back start at speed 100
What do i have to had/modify in my rgbcmdd.xml ?
Code: [Select]
<?xml version="1.0" encoding="ISO-8859-1"?>
<dat>
<header author="Gijs">
RGBcommander daemon config file for *nix based arcade cab
    <Application name="RGBcommander daemon" version="0.4.0.5" />
</header>
<options>
<!--Retropie 4.0.2 and up -->
<option
portnumber="2724"
led0="P1_START"
led1="P2_START"
led2="P1_BUTTON1"
retroarchbinary="retroarch"
rgbadefault="RANDOM"
activedefault="Orange"
inactivedefault="Black"
frontendbinary="emulationstatio"
waydefault="8"
</options>
<colours>
  <colour name="Off" rgb="0,0,0"/>
<colour name="Black" rgb="27,27,27"/>
<colour name="White" rgb="255,255,255"/>
<colour name="Red" rgb="255,0,0"/>
<colour name="Yellow" rgb="255,255,0"/>
<colour name="Orange" rgb="255,128,0"/>
<colour name="Lime" rgb="0,255,0"/>
<colour name="Green" rgb="0,255,0"/>
<colour name="Cyan" rgb="0,128,128"/>
<colour name="Blue" rgb="0,0,255"/>
<colour name="Purple" rgb="64,0,128"/>
<colour name="Violet" rgb="128,0,255"/>
<colour name="Magenta" rgb="255,0,255"/>
<colour name="Brown" rgb="128,64,0"/>
<colour name="Maroon" rgb="128,0,0"/>
<colour name="DarkRed" rgb="139,0,0"/>
<colour name="Firebrick" rgb="178,34,34"/>
<colour name="Crimson" rgb="220,20,60"/>
<colour name="Tomato" rgb="255,99,71"/>
<colour name="Coral" rgb="255,127,80"/>
<colour name="IndianRed" rgb="205,92,92"/>
<colour name="LightCoral" rgb="240,128,128"/>
<colour name="DarkSalmon" rgb="233,150,122"/>
<colour name="Salmon" rgb="250,128,114"/>
<colour name="LightSalmon" rgb="255,160,122"/>
<colour name="OrangeRed" rgb="255,69,0"/>
<colour name="DarkOrange" rgb="255,140,0"/>
<colour name="Gold" rgb="255,215,0"/>
<colour name="DarkGoldenRod" rgb="184,134,11"/>
<colour name="GoldenRod" rgb="218,165,32"/>
<colour name="PaleGoldenRod" rgb="238,232,170"/>
<colour name="DarkKhaki" rgb="189,183,107"/>
<colour name="Khaki" rgb="240,230,140"/>
<colour name="Olive" rgb="128,128,0"/>
<colour name="YellowGreen" rgb="154,205,50"/>
<colour name="DarkOliveGreen" rgb="85,107,47"/>
<colour name="OliveDrab" rgb="107,142,35"/>
<colour name="LawnGreen" rgb="124,252,0"/>
<colour name="Chartreuse" rgb="127,255,0"/>
<colour name="GreenYellow" rgb="173,255,47"/>
<colour name="DarkGreen" rgb="0,100,0"/>
<colour name="ForestGreen" rgb="34,139,34"/>
<colour name="LimeGreen" rgb="50,205,50"/>
<colour name="LightGreen" rgb="144,238,144"/>
<colour name="PaleGreen" rgb="152,251,152"/>
<colour name="DarkSeaGreen" rgb="143,188,143"/>
<colour name="MediumSpringGreen" rgb="0,250,154"/>
<colour name="SpringGreen" rgb="0,255,127"/>
<colour name="SeaGreen" rgb="46,139,87"/>
<colour name="MediumAquaMarine" rgb="102,205,170"/>
<colour name="MediumSeaGreen" rgb="60,179,113"/>
<colour name="LightSeaGreen" rgb="32,178,170"/>
<colour name="DarkSlateGrey" rgb="47,79,79"/>
<colour name="Teal" rgb="0,128,128"/>
<colour name="DarkCyan" rgb="0,139,139"/>
<colour name="Aqua" rgb="0,255,255"/>
<colour name="LightCyan" rgb="224,255,255"/>
<colour name="DarkTurquoise" rgb="0,206,209"/>
<colour name="Turquoise" rgb="64,224,208"/>
<colour name="MediumTurquoise" rgb="72,209,204"/>
<colour name="PaleTurquoise" rgb="175,238,238"/>
<colour name="AquaMarine" rgb="127,255,212"/>
<colour name="PowderBlue" rgb="176,224,230"/>
<colour name="CadetBlue" rgb="95,158,160"/>
<colour name="SteelBlue" rgb="70,130,180"/>
<colour name="CornFlowerBlue" rgb="100,149,237"/>
<colour name="DeepSkyBlue" rgb="0,191,255"/>
<colour name="DodgerBlue" rgb="30,144,255"/>
<colour name="LightBlue" rgb="173,216,230"/>
<colour name="SkyBlue" rgb="135,206,235"/>
<colour name="LightSkyBlue" rgb="135,206,250"/>
<colour name="MidnightBlue" rgb="25,25,112"/>
<colour name="Navy" rgb="0,0,128"/>
<colour name="DarkBlue" rgb="0,0,139"/>
<colour name="MediumBlue" rgb="0,0,205"/>
<colour name="RoyalBlue" rgb="65,105,225"/>
<colour name="BlueViolet" rgb="138,43,226"/>
<colour name="Indigo" rgb="75,0,130"/>
<colour name="DarkSlateBlue" rgb="72,61,139"/>
<colour name="SlateBlue" rgb="106,90,205"/>
<colour name="MediumSlate blue" rgb="123,104,238"/>
<colour name="MediumPurple" rgb="147,112,219"/>
<colour name="DarkMagenta" rgb="139,0,139"/>
<colour name="DarkViolet" rgb="148,0,211"/>
<colour name="DarkOrchid" rgb="153,50,204"/>
<colour name="MediumOrchid" rgb="186,85,211"/>
<colour name="Thistle" rgb="216,191,216"/>
<colour name="Plum" rgb="221,160,221"/>
<colour name="MagentaFuchsia" rgb="255,0,255"/>
<colour name="Orchid" rgb="218,112,214"/>
<colour name="MediumVioletRed" rgb="199,21,133"/>
<colour name="PaleVioletRed" rgb="219,112,147"/>
<colour name="DeepPink" rgb="255,20,147"/>
<colour name="HotPink" rgb="255,105,180"/>
<colour name="LightPink" rgb="255,182,193"/>
<colour name="Pink" rgb="255,192,203"/>
<colour name="AntiqueWhite" rgb="250,235,215"/>
<colour name="Beige" rgb="245,245,220"/>
<colour name="Bisque" rgb="255,228,196"/>
<colour name="BlanchedAlmond" rgb="255,235,205"/>
<colour name="Wheat" rgb="245,222,179"/>
<colour name="CornSilk" rgb="255,248,220"/>
<colour name="LemonChiffon" rgb="255,250,205"/>
<colour name="LightGoldenRodYellow" rgb="250,250,210"/>
<colour name="LightYellow" rgb="255,255,224"/>
<colour name="SaddleBrown" rgb="139,69,19"/>
<colour name="Sienna" rgb="160,82,45"/>
<colour name="Chocolate" rgb="210,105,30"/>
<colour name="Peru" rgb="205,133,63"/>
<colour name="SandyBrown" rgb="244,164,96"/>
<colour name="BurlyWood" rgb="222,184,135"/>
<colour name="Tan" rgb="210,180,140"/>
<colour name="RosyBrown" rgb="188,143,143"/>
<colour name="Moccasin" rgb="255,228,181"/>
<colour name="NavajoWhite" rgb="255,222,173"/>
<colour name="PeachPuff" rgb="255,218,185"/>
<colour name="MistyRose" rgb="255,228,225"/>
<colour name="LavenderBlush" rgb="255,240,245"/>
<colour name="Linen" rgb="250,240,230"/>
<colour name="OldLace" rgb="253,245,230"/>
<colour name="PapayaWhip" rgb="255,239,213"/>
<colour name="SeaShell" rgb="255,245,238"/>
<colour name="MintCream" rgb="245,255,250"/>
<colour name="SlateGrey" rgb="112,128,144"/>
<colour name="LightSlateGrey" rgb="119,136,153"/>
<colour name="LightSteelBlue" rgb="176,196,222"/>
<colour name="Lavender" rgb="230,230,250"/>
<colour name="FloralWhite" rgb="255,250,240"/>
<colour name="AliceBlue" rgb="240,248,255"/>
<colour name="GhostWhite" rgb="248,248,255"/>
<colour name="Honeydew" rgb="240,255,240"/>
<colour name="Ivory" rgb="255,255,240"/>
<colour name="Azure" rgb="240,255,255"/>
<colour name="Snow" rgb="255,250,250"/>
<colour name="DimGray" rgb="105,105,105"/>
<colour name="Grey" rgb="128,128,128"/>
<colour name="DarkGrey" rgb="169,169,169"/>
<colour name="Silver" rgb="192,192,192"/>
<colour name="LightGrey" rgb="211,211,211"/>
<colour name="Gainsboro" rgb="220,220,220"/>
<colour name="WhiteSmoke" rgb="245,245,245"/>
</colours>
<hardware>
<ledboards>
<ledboard name="PACLED64_1" hwthrottle="625">
<!--Only configure if used-->
<!--Example : The author's 2 player control panel layout-->
                        <control name="P1_BUTTON1" pin="1,2,3"/>
                        <control name="P1_BUTTON2" pin="4,5,6"/>
                        <control name="P1_BUTTON3" pin="7,8,9"/>
                        <control name="P1_BUTTON4" pin="10,11,12"/>
                        <control name="P1_BUTTON5" pin="13,14,15"/>
                        <control name="P1_BUTTON6" pin="16,17,18"/>
                        <control name="P1_START" pin="19,20,21"/>
                        <control name="P1_COIN" pin="22,23,24"/>
                        <control name="ALWAYS_ON_4-8WAY" pin="25,26,27"/>
                        <control name="ALWAYS_ON_SAVE_GAME" pin="28,29,30"/>
                        <control name="P2_BUTTON1" pin="31,32,33"/>
                        <control name="P2_BUTTON2" pin="34,35,36"/>
                        <control name="P2_BUTTON3" pin="37,38,39"/>
                        <control name="P2_BUTTON4" pin="40,41,42"/>
                        <control name="P2_BUTTON5" pin="43,44,45"/>
                        <control name="P2_BUTTON6" pin="46,47,48"/>
                        <control name="P2_START" pin="49,50,51"/>
                        <control name="P2_COIN" pin="52,53,54"/>
                        <control name="ALWAYS_ON_LOAD_GAME" pin="55,56,57"/>
                        <control name="ALWAYS_ON_SWITCH" pin="58,59,60"/>
                        <control name="P1_TRACKBALL" pin="61,62,63"/>
</ledboard>
<ledboard name="PACLED64_2" hwthrottle="625">
</ledboard>
<ledboard name="PACLED64_3" hwthrottle="625">
</ledboard>
<ledboard name="PACLED64_4" hwthrottle="625">
</ledboard>
<ledboard name="ULTIMATEIO_1" hwthrottle="417">
</ledboard>
<ledboard name="ULTIMATEIO_2" hwthrottle="417">
</ledboard>
<!--Example : The documentation writer's control panel layout , this has its hwthrottle value set to the lowest value that worked on the test hardware-->
<ledboard name="LEDWIZ_1" hwthrottle="1200">
  </ledboard>
<ledboard name="LEDWIZ_2" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_3" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_4" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_5" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_6" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_7" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_8" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_9" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_10" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_11" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_12" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_13" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_14" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_15" hwthrottle="10000">
</ledboard>
<ledboard name="LEDWIZ_16" hwthrottle="10000">
</ledboard>
</ledboards>
<joysticks>
<joystick name="SERVOSTIK" on="1" hwthrottle="0"/>
<joystick name="U360_1" on="0" hwthrottle="417" restrictor="0"/>
<joystick name="U360_2" on="0" hwthrottle="417" restrictor="0"/>
<joystick name="U360_3" on="0" hwthrottle="417" restrictor="0"/>
<joystick name="U360_4" on="0" hwthrottle="417" restrictor="0"/>
</joysticks>
<monitor on="0" delay="5000"/>
</hardware>
<mappings>
    <mapping name="static" active="Off" inactive="Off">
        <map id="default">
            <control name="P1_BUTTON1" colour="MidnightBlue"/>
            <control name="P1_BUTTON2" colour="MidnightBlue"/>
            <control name="P1_BUTTON3" colour="MidnightBlue"/>
            <control name="P1_BUTTON4" colour="MidnightBlue"/>
            <control name="P1_BUTTON5" colour="MidnightBlue"/>
            <control name="P1_BUTTON6" colour="MidnightBlue"/>
            <control name="P1_START" colour="MidnightBlue"/>
            <control name="P2_BUTTON1" colour="MidnightBlue"/>
            <control name="P2_BUTTON2" colour="MidnightBlue"/>
            <control name="P2_BUTTON3" colour="MidnightBlue"/>
            <control name="P2_BUTTON4" colour="MidnightBlue"/>
            <control name="P2_BUTTON5" colour="MidnightBlue"/>
            <control name="P2_BUTTON6" colour="MidnightBlue"/>
            <control name="P2_START" colour="MidnightBlue"/>
        </map>
        <map id="fs-uae">
            <control name="P1_BUTTON1" colour="OliveDrab"/>
            <control name="P1_BUTTON2" colour="OliveDrab"/>
            <control name="P1_BUTTON3" colour="OliveDrab"/>
            <control name="P1_BUTTON4" colour="OliveDrab"/>
            <control name="P1_BUTTON5" colour="OliveDrab"/>
            <control name="P1_BUTTON6" colour="OliveDrab"/>
            <control name="P1_START" colour="OliveDrab"/>
            <control name="P2_BUTTON1" colour="OliveDrab"/>
            <control name="P2_BUTTON2" colour="OliveDrab"/>
            <control name="P2_BUTTON3" colour="OliveDrab"/>
            <control name="P2_BUTTON4" colour="OliveDrab"/>
            <control name="P2_BUTTON5" colour="OliveDrab"/>
            <control name="P2_BUTTON6" colour="OliveDrab"/>
            <control name="P2_START" colour="OliveDrab"/>
        </map>
    </mapping>
</mappings>
<emulators>
<emulator binary="nes" name="Super Nintendo" active="Lime" inactive="Blue" retropie="0">
<rom id="default">
<control name="P1_BUTTON1" colour="Blue"/>
<control name="P1_BUTTON2" colour="Red"/>
<control name="P1_BUTTON3" colour="Black"/>
<control name="P1_BUTTON4" colour="Green"/>
<control name="P1_BUTTON5" colour="Yellow"/>
<control name="P1_BUTTON6" colour="Black"/>
<control name="P1_START" colour="Black"/>
<control name="P1_COIN" colour="Black"/>
<control name="P2_BUTTON1" colour="Blue"/>
<control name="P2_BUTTON2" colour="Red"/>
<control name="P2_BUTTON3" colour="Black"/>
<control name="P2_BUTTON4" colour="Green"/>
<control name="P2_BUTTON5" colour="Yellow"/>
<control name="P2_BUTTON6" colour="Black"/>
<control name="P2_START" colour="Black"/>
<control name="P2_COIN" colour="Black"/>
</rom>
<rom id="2048">
</rom>
</emulator>
</emulators>
</dat>
Thanks,  :notworthy:
LeSchtroumpf2
Re: RGBCommander with Recalbox blink my led
« Reply #1 on: October 12, 2020, 02:59:12 am »
Hello,
Nobody can help ?  :cry:
LeSchtroumpf2
« Reply #2 on: October 20, 2020, 11:10:11 am »
Hello,
I still have the issue. I'm starting to lose hope.  :cry: :cry: :cry:
Thanks,
mahuti
« Reply #3 on: October 20, 2020, 11:09:43 pm »
I've spent a lot of time with RGBCommander and wrote some of the documentation in the XML file. I'll take a look and see if I can offer any advice.
mahuti
« Reply #4 on: October 20, 2020, 11:42:54 pm »
From the XML documentation
- Added support for RecalBox 4.0.1  NOTE : as of writing (august 2017) RecalBox 4.0.1 is in unstable. RGBcommander has NOT been tested on 4.0.0 stable what 90% of the RecalBox users run. Once installed you need to configure it like RetroPie as described in this documentation. So yes, you need to specify retropie="1" etc even if you are on RecalBox
Code: [Select]
####################### STANDARD REQUIRED PARAMETERS
### binary Name of the emulator binary.
RetroPie: If retropie="1" (the emulator is a RetroPie managed binary)
then do not use the emulator's binary name, instead use the emulator's rom's folder name
####################### RETROPIE REQUIRED PARAMETERS
### retropie This identifies an emulator as being managed by RetroPie
If this emulator is part of the default RetroPie install,
or it was installed through the retropie-setup interface,
or if the emulator's rom's folder is in the RetroPie roms folder
then it likely is a RetroPie binary.
If so set retropie="1" (yes), otherwise retropie="0" (no).
Default value if not specified is 0.
### retropiebinary      If the emulator is a non-core retroarch emulator (like Advmame) Add this parameter with the name of the
binary itself.
So perhaps you need to set retropie="1" and use the rom folder name in place of the binary. Based on the log file, it looks like RGBCommander can't find the binary, this may be why. I think it runs a process to check to make sure the binary is running... if it can't find the process then it doesn't work. Kind of guessing here, but that sounds about right.
Code: [Select]
<emulator binary="ROM_FOLDER_NAME" name="Super Nintendo" active="Lime" inactive="Blue" retropie="1">
<rom id="default">
</rom>
</emulator>
LeSchtroumpf2
« Reply #5 on: October 23, 2020, 03:40:50 am »
Hello,
Thanks for your time and your work.
It f***ing works ! I spent so much time testing all and nothing :banghead:
Thanks a lot  :notworthy:
mahuti
« Reply #6 on: October 25, 2020, 02:45:03 am »
I'm glad you got it sorted.  :applaud:
Some of this stuff is very, very difficult to sort out. Even with apps I know and understand, I still have days where I can't figure out what the heck is going on. I was just setting up an install of LEDSpicer using an Ultimarc UltimateIO and for the life of me couldn't figure out why ONE button would not register. I can't tell you how many times I checked the software and the wiring. Turns out... one of the leaf switches wasn't making contact! All I had to do was slightly bend it and it was fine.  Even if one understands the software, and the hardware and everything else there's still some insane mystery.
Anyway, when you get it done, post a pic or video!
LeSchtroumpf2
« Reply #7 on: October 26, 2020, 12:22:38 pm »
Yes, i tried with others emulator and it works well :)
Ahah  it is the magic of computers !
I wanted a proof of concept and i have it. I have to do some woodworking now. But i'll came back with my project finished :)
Thanks again :D
