Author Topic: Will this 2-8ways 1-4way setup work?  (Read 1479 times)
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« on: February 21, 2004, 12:13:23 am »
I have my extended control panel made and laminated black it looks awesome. i ordered my buttons and im thinking about layout now. I have it planned out perfect except im not sure if my 4way setup will work, here is a crappy example of how i want it
8=8way
4=4way
0=button
______________________________
           0 0              4            0 0
     8   0 0 0 0                  8   0 0 0 0
          0 0 0                          0 0 0
the top buttons are start/coin, the rest are obvious. now i plan on using the 4 way with my left hand and using the right side buttons. but they will be mapped to player 2. so would i have to manually map the buttons to player 1 in all 4 way games, or is there an easier way around this?
"Owens is the ringleader in the ass hat circus"  D K
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:Will this 2-8ways 1-4way setup work?
« Reply #1 on: February 21, 2004, 12:37:12 am »
Wouldn't it be a ton easier to just buy a joystick that could switch between 4 and  8 way?  Both Ultimarc and GroovyGameGear are selling them.
But if you really have to have a 4 way and want to use the 2 player buttons, you are right on track, you would just need to map them within the game, unless someone has a clever way to create an all-encompassing .ini file....
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« Reply #2 on: February 22, 2004, 03:05:24 pm »
yeah, the switchable 4/8 way joy would make your life much easier...
If you don't want to map the buttons, then you'll need to add a couple to the right of your 4way and just wire them up with your other p1 buttons.
At this point, the CP is getting out of control...
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #3 on: February 22, 2004, 03:50:36 pm »
I just got the Ultimarc T-Stick Plus's with the ball top replacements.  They look REALLY good and the switching from 4 to 8 way is really quite cool.  You just pull on the top and twist.  I'd recommend going this route.
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #4 on: February 22, 2004, 11:26:30 pm »
well i already ordered my 8 ways, and even if i didnt i think this is the best route for me. for fighters i want non ball tops and for classics i want the ball tops, so instead of switching tops having a 3rd joy really isnt a problem.
