December 22, 2025, 05:00:58 pm
When developers integrate the Reflex SDK, they are able to effectively delay the sampling of input and game simulation by dynamically adjusting the submission timing of rendering work to the GPU so that they are processed just-in-time.
This is not a new feature actually. They seem to just have given it a new name.
I thought it was the (ultra) low latency mode, which they previously called "pre-rendered frames" or something (when set to 0/1). Are they really doing something else with this upcoming Reflex thing? Doesn't sound like it.
In the above image, we can see that the queue is filled with frames. The CPU is processing frames faster than the GPU can render them causing this backup, resulting in an increase of render latency. The Reflex SDK shares some similarities with the Ultra Low Latency Mode in the driver; however, by integrating directly into the game, we are able to control the amount of back-pressure the CPU receives from the render queue and other later stages of the pipeline. While the Ultra Low Latency mode can often reduce the render queue, it can not remove the increased back-pressure on the game and CPU side. Thus, the latency benefits from the Reflex SDK are generally much better than the Ultra Low Latency mode in the driver.When developers integrate the Reflex SDK, they are able to effectively delay the sampling of input and game simulation by dynamically adjusting the submission timing of rendering work to the GPU so that they are processed just-in-time.Additionally, the SDK also offers a feature called Low Latency Boost. This feature overrides the power saving features in the GPU to allow the GPU clocks to stay high when heavily CPU-bound. Even when the game is CPU-bound, longer rendering times add latency. Keeping the clocks higher can consume significantly more power, but can reduce latency slightly when the GPU is significantly underutilized and the CPU submits the final rendering work in a large batch. Note that if you do not want the power tradeoff, you can use Reflex Low Latency mode without the Boost enabled.
On a scale of fakeness, from more genuine to more fake, we'd have:1.- Plastic plants (cf. Fake Plastic Trees)2.- Inflatable dolls3.- Arcade cabinets with LCD monitors
