Author Topic: ROWE (Antique Apparatus) CD 100 software update to 4.3  (Read 5065 times)
Prop Nut...
  • Last login:January 19, 2021, 02:46:27 pm
« on: August 19, 2020, 10:38:44 pm »
In trying to ID the version software that I have in my Central Control Computer, (40832201) I found that the "system error" light was on. (see attached picture)
So, I want to upgrade to the version 4.3 software, on my computer, but I'm not sure exactly how to do that and now I am wondering what the system error might be indicating.
Can anyone help me decipher how to ID the error light and determine what version software I have and how do I upgrade it, please?
Ken Layton
  • Guru
  • Technician
Re: ROWE (Antique Apparatus) CD 100 software update to 4.3
« Reply #1 on: August 20, 2020, 12:11:01 pm »
Software version is right there on the chip label. I circled it in your picture.
Prop Nut...
« Reply #2 on: August 20, 2020, 03:50:01 pm »
Thanks Ken.
So am I to understand that all I need to do is swap out the EPROM chip, for a version 4.3 or should I find a CCC that already has it installed?
I ask, because I picked up a conversion kit (#66505907) to upgrade my CDM-3 to a CDM-12 and wanted to know if it cold work on a CCC with a 2.3 version EPROM chip, which is what I currently have on my CCC?
BTW, do I need to change my CDM-3 mechanism and carousel to a CDM-4 mech & carousel , in order to have the conversion kit work?
« Last Edit: August 20, 2020, 05:40:15 pm by Prop Nut... »
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 20, 2020, 09:27:40 pm »
Yes, just swap out the existing eprom for an eprom that already is burned with 4.3 software. Be aware that some early Central Control Computer boards only had a 28 pin IC socket and the eprom was a 512kb sized 27512 eprom. From software version 3.2 and up, a 1mb sized eprom (27010) is required. This larger IC also is 32 pins so a 32 pin socket may be needed. However, some Central Control Computer boards already have a 32 pin socket installed for the larger eprom. If it does, you'll see the smaller IC installed, but with 4 empty pins in the socket.
A complete CDM3 to CDM12 (a.k.a. CDPRO) conversion kit has everything you need. You DO NOT need to upgrade to a CDM4 with this kit.
Here are the instructions for the kit:
http://arcarc.xmission.com/PDF_Jukebox/Rowe_AMI/Rowe_Installing_CDM12_in_a_CDM-3_CDM-4_Kit_66505907.pdf
Prop Nut...
« Reply #4 on: August 21, 2020, 12:48:00 pm »
Ken, thanks again for your reply and the information.
I did check my CCC board, and have a 32 pin socket, with a 28 pin (ver. 2.3) eprom chip. (see attached)
I was under the impression that I needed to have a CDM4 since the instructions referenced it and also showed it in the drawings, when converting  over to a CDM12.
I also had read that the frame for a CDM4 was different, since it had a different CD player.
 BTW, I found a Rock-Ola eprom for sale (ROCK-OLA JUKEBOX EPROM #58824-3.9). I guess my question is, would upgrading to this version eprom suffice or is there more benefit to wait and find a version 4.3? For that matter, since I am convertion over to a CDM12, should I be looking for a ver. 5.3 eprom?
« Last Edit: August 21, 2020, 01:04:49 pm by Prop Nut... »
