Author Topic: 1976 Rowe ami R-80  (Read 3302 times)
RJP
  • Last login:August 23, 2020, 09:50:56 am
1976 Rowe ami R-80
« on: August 16, 2020, 04:36:12 pm »
Hi
I am new to this forum. I have the above referenced jukebox and my record arm seems to be on the fritz. When I select a record the carousel picks it up, puts it down and then the record arm moves a little to th3 right, And then stops and moves back. The record is then picked up and put back into the carousel. To repeat I have to press the credit button in the jukebox.
Any ideas?
Thanx for your help
RJ
RJP
Re: 1976 Rowe ami R-80
« Reply #1 on: August 17, 2020, 01:12:16 pm »
As Rosanna Rosanna Dana says “ Nevermind”
Got it working along with making it play without having to press the interior credit button everytime
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 18, 2020, 11:25:35 am »
We never had any R80s on our route. We had MM2 through MM6 then we started with Rowe again with the R83 and up. We had then standarized on Rowe equipment because it was the most reliable and best sounding.
