Author Topic: Rock ola 474 amp  (Read 4304 times)
DaveN
  • Last login:August 12, 2023, 12:26:17 pm
Rock ola 474 amp
« on: August 10, 2020, 03:58:49 pm »
I just pick up two Rockola 474's and the one I'm working on has static in the right speaker all the time sometimes you can hear it over the music. I have replaced most all of the electrolytic capacitors on the driver board, the pre amp and the power board with no change in the noise. has any one ever had this before.
Thank you for your help
Dave Niccum
Georgetown, Il USA
whammoed
  • Last login:November 17, 2025, 11:13:27 am
  • Crack don't smoke itself
    • NiceMite
Re: Rock ola 474 amp
« Reply #1 on: August 31, 2020, 04:29:35 pm »
check your connections too.  I had an occasional static issue that ended up being the speaker terminal lugs were not screwed down securely.
