Author Topic: Monitor Width - UAII Cab  (Read 1667 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: February 19, 2004, 04:47:53 pm »
I'm currently building a UAII cab, standard width (25")
That leaves me with 23 3/4" of width available for a monitor (using 5/8" MDF)
I'm going to use a 19" PC monitor to start, but might put in a "real" WG monitor down the road.
What size of monitor do you think I could get in there with that width available?
Thanks.
%$#@!&* machine took my quarter!
nipsmg
  • Last login:March 07, 2026, 12:08:50 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re:Monitor Width - UAII Cab
« Reply #1 on: February 19, 2004, 04:52:20 pm »
That width is INTERIOR width.
If you built it to 25", you have 25" for a monitor.
I remember reading a thread where someone got a 25 in monitor into a centipede with a custom frame, so I'm pretty sure you can fit a 27in monitor in there if you customize it.
I built mine to 27in on the top.... I can just fit a 27in monitor, but it's also got a large frame on it.
--NipsMG
Oldskool
« Reply #2 on: February 20, 2004, 01:26:58 am »
You're right about the width (brain cramp).
When I said that I'm currently building, I used the word "currently" loosely. I've only actually cut out a few pieces..... :-\
Here's a link to the WG site.
http://www.wellsgardner.com/wellsgardner31/supportdata/27%20inch%20D9200%20black%20&%20white.pdf
It shows their 27" monitor as being 24.390" in width, so it should fit fine should I decide to go that route someday.......
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #3 on: February 20, 2004, 02:12:20 pm »
The centipede cab is 23.75" wide internally as well, so you should be able to fit a 25" monitor in there as long as the mounting ears are not on the sides of the tube.
