Author Topic: A-PAC or U-Hid - which should I use  (Read 3123 times)
portyman
  • Last login:May 02, 2025, 08:34:29 pm
« on: June 13, 2020, 09:11:28 am »
I am building a pole position/ off road cab with a raspberry Pi and 360 wheels. I have an analog potentiometer gas pedal and brake set. I use a mini pac for buttons and joystick. What should I use for the pedals. I will eventually get 2 more gas pedals to use for the off road game but I’m starting simple at first. It’s my first uses of anything with Pots.
  • Last login:Today at 01:46:36 pm
Re: A-PAC or U-Hid - which should I use
« Reply #1 on: June 13, 2020, 01:38:52 pm »
Several approaches to this:
1. Use your Mini-Pac for the buttons, joystick, and 360 wheels.  Use a U-HID nano for the pedals.
- Two 360 wheels are electrically the same as one trackball.
2. If you want to fit all of the controls on one hybrid encoder board, you're looking at a full-size U-HID.
- It's a bit expensive for some people's budget but a very powerful and flexible encoder.
3. You can roll-your-own joystick/button, optical, or analog encoders using inexpensive 32u4 Arduino boards.
- Costs far less than the encoders mentioned above, but requires some soldering skills and loading the desired firmware on the board.
Dedicated admin buttons or shifted functions?  http://wiki.arcadecontrols.com/index.php/FAQ#Number_of_admin_buttons
How many of each type of control will you need for your final build?
  2 - 360 wheels (optical encoder)
  4 - potentiometer pedals (analog/gamepad encoder)
  __ - admin and player buttons (gamepad or keyboard encoder)
  __ - joysticks (gamepad or keyboard encoder)
Based on that info, you can determine how many inputs/connections you'll need.
http://wiki.arcadecontrols.com/index.php/FAQ#How_many_encoder_inputs_do_I_need_for_my_control_panel.3F
A 360 wheel is an optical (mouse) control.
- 5v
- Ground
- Two data lines ("quadrature waveforms")
A potentiometer is an analog control.
- 5v
- Ground
- Input for variable voltage from the wiper (center tab)
Buttons/joysticks are microswitch controls.
- Input
- Ground
portyman
« Reply #2 on: June 13, 2020, 02:02:23 pm »
Awesome..thank you. I think option 1 is the best for me since I have the mini ipac already and my soldering skills are terrible.
